bsabloke wrote:Post up your location mate. People nearby may be able to help. I have a spare set of carbs complete & may be able to help you
My location is Holland
tony.mon wrote:That little tongue is not under a great deal of leverage and torque, as the spring it's pushing against isn't very strong.
Certainly a repair is worth a try, also possibly aralditing a small "splint" to it, if there's clearance between the face of the tongue and the housing- a pop rivet stem would do.
That little black disk thingie does that turn with the spring or is it locked in place?
Any help is appreciated
The only thing is that shipping from UK to Holland isnt cheap and vice versa.
So actually im only looking for a loose TPS, cause it can be chipped in an envelop with bubbles inside
Im trying to find one in Holland, only i dont really know the dutch translation for TPS, cause im always googling in english haha
Ill will also try to fix the old one, only i dont know how the spring and disc where mounted originally cause it came loose.
