Rear End Squeeks?
Rear End Squeeks?
Ok folks had a little squeek as summer came on and we finally had some dry weather. Quick and easy diagnosis you should all know it by now, the rear suspension linkage.
After some liberal spraying with the good old WD 40 squeek stops, Pete stops worrying about it. Well guess what's happened now.... No, no squeek, I thought I was just putting up with cold slimey roads and half worn tyres, the bike was handly poorly at low speeds and untill I washed it this morning I didn't even know I was in trouble. Have a look at this
So, if you've got a squeek go out and inspect it, strip it and regrease/ bush it and do it before it trys to kill you 8O
Max
Post by Max »
You were a bit lucky, If that had broke you would have had no chance.
Good spot.
Max
Seeker 77
Post by Seeker 77 »
8O 8O 8O 8O :eek2 :eek2
8O That was a bit close for comfort Pete :!: if you'll excuse the pun :!:
Glad you found it in time mate,
Chers Guys
Went cold when I first spotted it, kept staring at it thinking "No that can't be right"
Then went into instant pissed off mode cause I had planed to get a trade in this afternoon on another SP2 I've had my eye on.
Seams my new bike plans are doomed :twisted: :twisted: :twisted:
Oh well, guess I'd better get this sorted and start again :cry:
RAINMAKER
Post by RAINMAKER »
The law of sod in action again.............but could be worse.
it may be clever, but its not big.
yellafella
Post by yellafella »
kin ell Pete !!!!! 8O 8O 8O
Rushed straight out to check on mine !!!
Er . . . . . how much do you weigh ??????????? :lol: :lol: :lol: :lol:
kevg
Post by kevg »
Oh great, something else to worry about now. :(
cheerz
kev
xxxrated
Post by xxxrated »
its funny u mention this because as i got back from todays rideout and parked my bike up it started making a squeeking noise. i dont know if this has anything to do with it but i adjusted the rear shock 1 notch on the top to make it a bit sofeter. would this have anything to do with it?
iggy1966
Post by iggy1966 »
That looks a bit nasty Pete :?
Good job you spotted it when you did!!!
"Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."
firestorm_al
Post by firestorm_al »
When I saw your topic title I was about to say that you need to inspect the bearings on your rear suspension linkages but I guess that you've noticed what the problem is!
After having all the bearings replaced make sure you re-grease them once a year.
Al.
xxxrated wrote:its funny u mention this because as i got back from todays rideout and parked my bike up it started making a squeeking noise. i dont know if this has anything to do with it but i adjusted the rear shock 1 notch on the top to make it a bit sofeter. would this have anything to do with it?
Could be xxx.
With a softer spring you'll get a little more travel so it's worth checking it out. Just remember lads (and lasses) put a block under the engine or use a center stand (one that attaches to the engine) before you heave the main bolt out :wink:
And, yes I did use one before anyone asks :P
Preventative maintainance....Whats that???
tony.wilde1
Post by tony.wilde1 »
how about drilling the bolts and tapping them to accept grease nipples?one quick squirt every now and then and ....sorted.going to do mine this winter for sure! :)
:D You and your greased nipples :D
Definately got a one track mind Tony......aah, got any piccies??
tony.wilde1
there you are pete!! :lol: :lol: :lol:
