Wanted fuel filters
macdee
Wanted fuel filters
Post by macdee »
as above men
what size fuel line filters and where to get them
thanks
Re: Wanted fuel filters
There's a thread on this somwhere and I have provided links to various filters on eBay but for the life of me I can't find it. It must be slipped into a thread that went slightly off topic. I shall keep searching.
The fuel pipe is a 10mm diameter but it's a struggle to find 10mm inline fuel filters. 8mm should be OK and has been used by a few members.
Oh I give up. Still been looking for that thread but no use. It's annoying me now as I'm pretty good at searching older threads. I must whack a keyword in there when it crops up again. :(
Virt
Post by Virt »
What is the need for inline fuel filters? I thought tanks normally came with them...
Your right there is a filter inside the tank so if everything is in good order then there is no need. Inline filters are just an extra security precaution. It's a lot easier to keep an eye on the condition of inline filters and change than the internal one on the tap. IIRC some more expensive filters also come with a quick release system which could be handy when removing the tank.
Virt wrote:What is the need for inline fuel filters? I thought tanks normally came with them...
just in case the filter in your tank has given up the ghost, a second filter(inline) will give you peace of mind young padawan.... :thumbup:
Virt
Post by Virt »
Ohhh I see. That makes sense :lol: Thanks Laurel & Hardy :thumbup:
macdee
Post by macdee »
I ran the tank low on fuel and I think I picked up a little water which may have been in the bottom
the bike won't run now so the carbs are off for a clean
They look immaculate inside so I think it's water :roll:
All good as I have done my tps which was at 900 ohm :D
Carl I have looked and can't find the thread either
