Exhaust, tell me why....
My LH muffler is much louder than my RH muffler?
Maybe I need to open up the restriction in the RH pipe to make them the same?
Re: Exhaust, tell me why....
You need to repack it as the left is the main one and the right is the over flow
No don't remove the restriction in the righthand header pipe,
Why? Its not a tuned system.sirch345 wrote:No don't remove the restriction in the righthand header pipe,
They must be hard on packing, I did it 3 months ago. But she does seem louder than before.lloydie wrote:You need to repack it as the left is the main one and the right is the over flow
The standard system is a tuned system .
The only mod to do to it is to fit race cans and reduce the welds on the inlets leave the rest be
They seem to disagree here, http://ozfirestorm.proboards.com/thread/1929/modsirch345 wrote:No don't remove the restriction in the righthand header pipe,
Denied Access from the oz forum
If it helps I found this response a good while ago about it all, I found it funny and informative:
> > The restrictor in the standard headers is there to
> > assist the pulsing which
> > helps to scoure the front cylinder and to create a
> > turbulence vacuum thus
> > accelerating the gas speed at that point above certain
> > revs. If this is
> > removed the left hand exhaust can will discharge a
> > greater proportion of the
> > gas emmisions.as did the first Akropovic and Two
> > Brothers full exhausts did,
> > until they were modified, to the detriment of the
> > engine performance. Later
> > full systems were designed to overcome this effect by
> > changes in their
> > length, merge angles, tapers and taper length.
> > Honda, Moriwaki, Akrapovic and others could have
> > saved themselves
> > millions in R&D if they had only listened to some AU
> > guy and cut away the
> > "excess" to improve power output !!!!
> > revs. If this is
> > changes in their
> > saved themselves
does that mean both my akra full system and two brothers full system are pants.........
I wonder if lloydie will buy them from me......
I think we need a full range of exhaust systems and headers represented at the next Dyno day. then we can see what each one is doing.
on my headers I have just removed the welds at the joint to the heads didn't touch the intersection.
those Remus pipes I have on now are running so well, I think I have filled in the mid range dip as well as having extra at the top end. best set up the bike has had and obviously working well with the inlet trumpets.
and to top it all the fuel consumption is slightly better too............ hence I just need to check on the dyno that it is not too lean
Yes yes yesagentpineapple wrote:does that mean both my akra full system and two brothers full system are pants.........![]()
I wonder if lloydie will buy them from me......![]()
I'll refit my mori for the Dyno as I can't have the banana beating the frog !!AMCQ46 wrote:I think we need a full range of exhaust systems and headers represented at the next Dyno day. then we can see what each one is doing.
lloydie wrote:I'll refit my mori for the Dyno as I can't have the banana beating the frog !!AMCQ46 wrote:I think we need a full range of exhaust systems and headers represented at the next Dyno day. then we can see what each one is doing.
I will add Nitrous oxide
You might as well (just to get there ) :-)
