Wanted: goosed engine
Moderator: VTRDark
- Redthunder
Midlands area, cheap for project
How goosed as I have one with front mount damaged and burning lots of oil .
No cases or cams or flywheel or clutch .
And an other one with the heads missing and other bits missing but all mounts there
- Redthunder
Re: Wanted: goosed engine
Internals can be as seized.
Want the heads but not bothered about side cases. Prefer flywheel on.
Coffee table!
Coffee table!
Ok mines be no good
I have a pair of heads, they are complete with cams & covers & no damage.
We've all got a set of those, Chris, bike won't run without them.chris freckle wrote:I have a pair of heads, they are complete with cams & covers & no damage.
this is true but the items I have are not attached to an engine, my engine has another set and it is in a bike which is for sale
Two heads are, indeed, better than one for a twin.
There's a lot to thank those old wives for, with the exception of spitting on corners of handkerchiefs and wiping people.
Ebola and HIV have stopped that sort of nonsense!
You have got me there, I don't have a clue what you are talking about. I will try sell the heads on the bay of flees, rather than try to help a fellow org member out.
Ok. I wondered why you would try to sell a fella who's after a complete engine to use as a coffee table base a pair of perfectly usable heads?
Ebay seems a good idea.
Anyone who wants them will bid.
That would be because He said he wanted heads but was not bothered about the rest, for a group of people enjoying an old Honda it all seems a bit to clique to me. I can't be bothered.
It's not a clique Chris, it's called humour, chill out a bit & join in the fun...Still if you have a clique best check your CCT's or Shim's...or it could be the chain needs adjusting as it's hitting the link pipe...chris freckle wrote:That would be because He said he wanted heads but was not bothered about the rest, for a group of people enjoying an old Honda it all seems a bit to clique to me. I can't be bothered.
Chill out pills are available from all good dealers...
Hope that helps.
Stick Tony and Chris in a corner together and it will be two oldies together having a banter. Their probabley about the same age Even I have to read Tony's humour over a couple of times sometimes...and I know what he's like.
