What are you currently ignoring on your bike?
Re: What are you currently ignoring on your bike?
Virt wrote:Yeah, 4 inches short but honestly the cans do look shorter than that!
Cough cough 3"
Virt
Post by Virt »
Cough cough 3"
Mine are 380mm.. I thought standards were 480mm?
Your knob :ball kick: .
I have a mahooosive long list of jobs, but i'm still waiting for carl..... :lol:
tbh none of the jobs are essential, so they'll get done towards the end of the year.
YELLOW BIKE.....
finish and fit gpi
fit usb charger
fit battery charge lead
tinker with carbs
fit brembo pads
braided lines
fit sp2 front calipers
fit armstrong discs all round
use quality clutch and brake fluid
fit glsr sprocket cover
get front forks rodgered
and that's just the yellow'un, the blue ones list is twice as long with a lot bigger jobs.... :roll:
Ok my list for piggy
Parts needed
Rear shock
Front brake calipers
Front Brake lines
Front brake discs
Bars
Pistons hi comp
Engine mount bolts
Link pipes
Battery
Fork springs
Fork bushes
Brake pads
Crush rubbers
Jobs to do
Engine build (mostly by roger)
Get spacers made for the 07 rear wheel .
Weld swing arm brace on,
Brace the frame ,
Rebuild the forks,
Then build it all up as it's in many boxes :lol:
Geoff S
Post by Geoff S »
For the last 1500 miles or so I have been ignoring my CCTs.... :shifty:
Did the stopper mod today so now the fear is gone!
May have to stop ignoring the fact that my fairing is red and my tank and tail are orange next.... :roll:
Ignoring the All Balls taper roller head bearings, that I only fitted at Christmas, which are now self centering because I ignored the fact that they had too much slack in.....
popkat
Post by popkat »
Currently trying to Ignore the gravel rash and the rest of the damage since the poor Kat hit the kitty litter :roll:
popkat wrote:Currently trying to Ignore the gravel rash and the rest of the damage since the poor Kat hit the kitty litter :roll:
Now, now young Malc me Lado, Donington will be upon you quicker than you think. Back in the workshop ASAP...Or it's the long nights the week before again.
Bananaman
Post by Bananaman »
..........the vibration through the bars under heavy braking :thumbdown:
Slightly concerned I might have warped discs, but tomorrow's job is to check all the bobbins are free n a bit more preload methinks :think:
Four wheels move the body,
Two wheels move the soul.
bigtwinthing
Post by bigtwinthing »
Bananaman wrote:..........the vibration through the bars under heavy braking :thumbdown:
warped discs feels normally like "pulsing"as the pistons move in and out, pushing the fluid back and forth as you squeeze.Vibration may be a sticky piston, wheel bearings, loose or broken bolts (I've known a forkleg bolt snapped but held in place due to corrosion and it gave this fault).
Its a good idea to undo, lube (careful Lloydie) and re torque all bolts up. You can't simply hold a match against your disc (with the wheel free of the ground) with some blutac and spin the wheel. it will show if there warped.
ging500
Post by ging500 »
I don't have my SV anymore and I can honestly say I don't miss having to ignore things wrong the bike!! Or the stress of it breaking every week!!
Bananaman
Post by Bananaman »
Cheers :thumbup:
Also is 500 ml of oil every 120 miles usual? :think:
bigtwinthing
Yes if it has no Piston Rings!!! That seems mighty excessive to me!, what do you guys think?
My old one used more than that .
Pulled well ran well just used oil like a two stroke .
As long as you know it uses it and you keep it topped up it's fine
