The Tuono lives on....
Re: The Tuono lives on....
Power and weight loss !:-(
You have a challenge a head of you
And your challenge will be to stay on the track !!! Mr green lane rider or is that oh sh1t missed the apex again I'll try the grass !!
I like to be different and live life at the edge. Some times I will even manage to go off the edge of the track and on to the grass
Lloydie likes to be different and "live life in the hedge"Ckennedy wrote:I like to be different and live life at the edge
Loving the clipons CK, can you feel much weight difference between the carbon and f/g fairings?
Jamie
Back brake might work now
“Only by constantly developing your insight and knowledge can you fulfil your responsibility to ride safely and effectivelyâ€
There's a huge difference Jamie. It has to be half the weight at least :shock: when I get chance and if my scales are good enough I'll weigh them and find out.
The back brake always worked geo, after we messed around with it
now it will stay working, well it will when I have sorted out a new shorter braided line for it
Well I'm shocked. I dug out the kitchen scales and weight all the carbon stuff vs the fibre glass and I'm shocked. I need to get a digital pair of hanging scales to weigh them properly as from what I have there isn't a lot of difference but when you pick them up you feel a bigger difference. So when I have some better scales I shall 're measure and let you know
Hmm that's odd... maybe your right arm is much stronger than your left?
lol
But you did mention they have been covered in grp, so that would beef them up.
lol
Jamie
Yeah. It's almost tempting to try stripping the gel coat off them to make them even lighter, but that's to much hard work
The carbon parts are reinforced .
Normal gel coat ,layer off glass then a layer of carbon .
Look down the edge you will see the layers
Today has seen me back at Lloyds for the first time since Christmas and I came armed.....
With the track fairings and tank
Took longer to fit than I first thought as I had to trim the side panels to fit around the crash bungs, make a start at cutting the half carbon belly pan
which needs a lot more work to fit with it having the 2-2 akra system on it
got the rear sets fully fitted, just need to refit the rear brake line and wire in the brake light switch, then bleed and that will be done.
Still waiting for the shock to come back
and I'll get the springs for the front at the same time and then it's nearly there. Still going to have a play with the look of the fairings as there not in the best condition but there useable.
Got rather excited when I sat on her. Feels like a nice position but will only find out when riding
Loving that mate, much better than sit up and beg, looks the tits too!
Jamie
Yeah it looks good. Would need a lot of work to be perfect though
maybe one day
