master cylinder
master cylinder
I cant find the thread about changing the master cylinder. as opposed to the calipers.. for improved braking..pointers please....
I AM THE STRANGE MAN YOUR MOTHER WARNED YOU ABOUT......
Have a sweetie and stop crying........
[Werthers Original...they never get rid of the taste]
Martin,
This what your after??
bluesman
Posted: Wed Dec 07, 2005 7:59 pm Post subject: pump
mainly it is down to master cylinder and ampliying ratios.
Put on master from RC51 and you will be amazed with difference.
Why they got it wrong on VTR - have no clue....
Basically I heard from some guys who tried it that combination of VTR pistons, braided lines, good pads and RC51 master cylinder makes VTR brakes completely satisfying.
bluesman
"Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."
- Stormin Ben
I personally can't see the reason for a more powerful master cylinder.
Fit some braided hoses and decent pads and most importantly, clean the calipers regularly!
Then there's more than enough stopping power with only two fingers, yet you can scrub off speed while leant over coz they've also got feel and finesse
Ben
Ben
ive got both calipers and a master cylinder waiting to be fitted...ive been bitten by the modding bug , so i guess this is where it starts..i find the brakes on my storm fade badly after about a dozen laps on circuit..and it was only serviced last weekend...dont know weather ill do both tho...?
- Stormin Ben
That'll be EBC HH brake pads will it?Zer0Zer0 wrote:..i find the brakes on my storm fade badly after about a dozen laps on circuit..and it was only serviced last weekend...
That was the problem I had so went looking for replacements
Carbone Lorraine SBK3's
- ace on track, no fade (in fact the opposite, they come on stronger as they get hotter. Lovely lovely lovely)
- crap on road coz they don't get hot enough
Bendix supersport
- Great on track although not quite as good as the CL's
- Good on road (not quite as much initial bite as the EBC's)
Carbone Lorraine A3's
- Great on track. Not as good as SBK3's but still no fade
- Great on road. Work from cold, in the wet but still not quite as sharp as the EBc's at the initial bite point
Ben
- Stormin Ben
Don't see why not, wouldn't be any more hastle coz I remove the pads and clean my calipers before every one anyway
Just make sure you release the pressure in the brake system after you swap over (thicker pads will push the pistons back more than normal and if you don't release the pressure they'll drag and warp your disks)
Alternatively, bleed the system with the thicker pads in and that way you'll not have the problem. Just remember to pump the pads back out again BEFORE setting off -had a moment at Cadwell last year as I whistled into the collecting area having just swapped the wheels
Ben
Ben
