No Spark-No Go + massive frustration!
Re: No Spark-No Go + massive frustration!
Delete your number form a public forum mate I will pm what you have wrote including your number to him.
Carl - many thanks - I was hesitant but did not know another way of making contact without revealing more details about myself - you can tell I dont use these forums too often! Gcybercarl wrote:Delete your number form a public forum mate I will pm what you have wrote including your number to him.
- bigtwinthing
Gr8whenitgoes wrote:Carl - many thanks - I was hesitant but did not know another way of making contact without revealing more details about myself - you can tell I dont use these forums too often! Gcybercarl wrote:Delete your number form a public forum mate I will pm what you have wrote including your number to him.
my number is 07789500575 ring it if you want to be bored to death
Is that the local ruby house.
So Roger came with his VTR and tested my converter and Ign Control units - Thanks to him -, both of the units worked ok, so I slaved the wires from converter to coil, but no change; still no spark on the front cylinder. Be grateful if anyone has some more ideas G
All that is left is going back to the basics. I know you say you have checked all this but plug, lead, coil. Work your way backwards. I'm at a loss here. Something has got missed amongst the checks along the line.
Good advice Carl, and I'm going to make up a peak voltage adapter, and go through the system (again) - thankscybercarl wrote:All that is left is going back to the basics. I know you say you have checked all this but plug, lead, coil. Work your way backwards. I'm at a loss here. Something has got missed amongst the checks along the line.
It'll probably be a fractured lead issue somewhere, giving intermittent continuity. Using your DVM what is the resistance between the battery earth terminal and each cylinder head?
If you've over-cooked it, just lean it over more.
Humm this is truly weird. As carl says back to basics I would be, at this stage, questioning the loom.
I just realised this does not sound good. "but plug"I know you say you have checked all this but plug
Change the loom it's cheap and simple
Really appreciate the recent posts. Got fed up with the honda so took a bike that works out for a spin over the Yorkshire Dales and Devils Bridge - as always coming back with a smile! but no VTRs at Devils Bridge to have a chat! I'm almost at the point of changing the harness Lloydie but determined to find a cause, so I will be partially stripping the harness - carefully but not today-visitors! G
thanks for this - Earthing has been well tested, and not a problem - and to make sure when I am testing I use jump leads to earth the plugsATM wrote:It'll probably be a fractured lead issue somewhere, giving intermittent continuity. Using your DVM what is the resistance between the battery earth terminal and each cylinder head?
SO here's a thing. I've now changed the wiring harness - cleaned all contacts etc - and on first start the front sparked well, but then became erratic and now has died completely. The rear keeps sparking well. I have not been able to reliably measure the ignition trigger or converter output voltages; but the trigger and primary/secondary coil resistances are in spec
Could a weak Ignition Triger Voltage output lead to a low Converter output? The only difference in the system is the distance from Converter unit to front coil is much greater for the front cyl than the rear - leading to slight increase in volt drop to the front - clutching at straws now comes to mind!
Any thoughts would be welcome as usual!! or has anyone been able to reliably measure the trigger and converter output voltages? if so how?
if anyone can sort this I'll buy him a beer or 2! now for me thats generous!
Regards
Regards
Wow this gets stranger and stranger.
Basically either up or down from the centre line is on or off and any excess peaks will be voltage spikes.
FYI The pulse generator/ignition trigger usually fails at higher revs. So let me get this right, the front wasn't sparking at all but then did initially spark once the harness was changed.
Not sure but if there is a big spike this may damage the converter unit which bring me onto you next question.Could a weak Ignition Triger Voltage output lead to a low Converter output?
I have not done it myself as it would require the use of an Oscilloscope to view the Sine wave and you will see it switching on and off by the wave pattern.has anyone been able to reliably measure the trigger and converter output voltages? if so how?
