Cush drive
Yellowone
Cush drive
Post by Yellowone »
Could any one tell me how much movement is allowable in the Cush drive before they need replacing please
Other bikes yamaha fz1, ktm 660
Re: Cush drive
If you suspect it needs replacing it probably means they do - as a bodge to get the last bit of cushioning in the drive system you can shim the rubbers with thin plastic from an ice cream tub (© Benny hedges) - coconut works best...
bald_pig
Re: Cush drive
Post by bald_pig »
Wicky wrote:If you suspect it needs replacing it probably means they do - as a bodge to get the last bit of cushioning in the drive system you can shim the rubbers with thin plastic from an ice cream tub (© Benny hedges) - coconut works best...
A common bodge I learnt from the XT forums is to use an old inner tube, cut it up and pad out the cush drive rubbers.
