Regulator power drain
Re: Regulator power drain
I have continuity from the red wire to only the bottom left pin on the fused starter block connector
Everything is testing as it should, everything is grounded, and the regulator gets so hot you cant even touch it after about 1 min at idle. Im starting to lose it over here...
Im starting to think since i am not seeing higher than 12.8 v at battery during fast idle, and that i am getting upwards of 50v ac from the stator at 5k rpm that this ebay regulator is just sh1t. Maybe thats why its shunting so much and not providing the right charge. Ill order a new one from a reputable dealer and try that. Really starting to lose my patience and ready to slap a for sale sign on this....
My reg does get hot but not so hot it'll burn your hand, even after a run.
Does sound like a poorly reg
Sent from my SM-G850F using Tapatalk
I got another one due here in a few days, just went for a short ride, and battery is still at 12.7v after but reg still super hot. I am hoping the reg is just sh1t and i can resume riding!
Don't loose it juts yet. Sort the little niggles out and you will have a superb bike. Please make sure you battery is good too as a dodgy R/R can kill a good battery and vica verca. Don't get caught up in a vicious circle.Really starting to lose my patience and ready to slap a for sale sign on this....
Battery is recently new, new regulator came in today. Has proper charging volts at idle (14.2-5 at battery terminals) but still gets very hot after a very short time. Both combos of grounds ( straight to frame/through reg nut) and still the same. So i guess it is still shunting a large amount to the frame. Stator overcharging? What am i missing??
You could check by doing the later tests n the following:
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=28771
If everything checks to be OK then I would not worry about it. Non-Mosfet R/R's do get hot to the touch...very hot at times. Especially the smaller finned type unlike the old R1 R/R's. You may also want to take the earth directly from the battery too as this may make a difference.
- firestorm_al
- Site Admin
- Contact:
Switch your lights on and increase the draw from the R/R so that it is shunting less!Pistonguy wrote:Battery is recently new, new regulator came in today. Has proper charging volts at idle (14.2-5 at battery terminals) but still gets very hot after a very short time. Both combos of grounds ( straight to frame/through reg nut) and still the same. So i guess it is still shunting a large amount to the frame. Stator overcharging? What am i missing??
Yeah i have been running the brights, an it IS a OEM style black rubber box one. I think i will just ride and see how long it lasts. After reading up on it i am confident i can do the mosfet swap, so when this one burns out ill upgrade! At least the bike charges and isnt leaving me stranded anymore lol
Like this?
![Image](http://cl.ly/image/0c2E2I230S0z/vtr-R-R-smallish.png)
If so junk it ASAP and fit a MOSFET before it does leave you stranded and with damage not just to the battery but to other costly electronic components, or even setting fire to the bike![EEK! :eek2](./images/smilies/eek.gif)
Yes like that, but the stock one was also like that... And lasted 11000 miles. It gets very hot, so within two weeks ill probably spring for the zx6 mosfet. I think it will be easier to wire with the wires attached.
Just splice this Triumph mosfet plug adapter into your VTR's wiring when you get your FH marked R/R
http://www.vtr1000.org/phpBB3/viewtopic ... 82#p351482
![Image](http://i142.photobucket.com/albums/r94/kato--/leadsd_zps75b93143.jpg)
Oooh. Which model is that?
This looks like its getting easier and easier lol
