Chain Lube
CaperJ
Chain Lube
Post by CaperJ »
What is the best in your opinion I am using castrol but find chain dries quickly and clicks.
CaperJ
Nigel
Post by Nigel »
I use castrol chain wax on mine, but I cleaned the chain thoroughly before applying it for the first time. I clean the chain properly once a fortnight and re apply, I also give it a quick squirt in between after going out for a run when the chain is hot. Since using this method I have had no trouble and have not had to adjust the chain since, but I am considering getting a scottoiler.
andy c
Post by andy c »
I agree with nigel castrol chain wax i dont clean my chain as often as he does but still no problems
andy
stormy 1
Post by stormy 1 »
I have always used castrol chainwax,but I was talked into useing repsol fully synthetic lube(very expensive!!! :? )and was told you get no fling,but I got fling on the first application :x then none after.On having the lube tested(I work in the aircraft industry)it seems very strong and my chain looks to be in good nic :D .
noise polution?,you should see my MPG!!!
VTR1000fw,scorpian cans,dynojet and K&N all wrapped up in HRC colours.I need a HRC avatar!.
CaperJ
Chain WAX ?
Post by CaperJ »
I have what is called chain lube it is black is that the same ?
W@zzA
Post by W@zzA »
I swear by Castrol Chain Wax, every 3-4 days daily riding, no fling and the small can they do is handy for long trips.
