All the fun of a crud infested bike that looked like it hadn't seen a sponge in its life...
Supplide a new set of cush drive rubbers & noted the the rear pads were down to about 1/2 a mm of material so swaped those as well & finaly re-bled the clutch through with nice fresh Dot 4 as what was in there was black...
Next job for you Jeff is is strip the rear end all down again & check the linkage's ! Oh & give the thing a bloody good clean ! Then do the brake fluid as well...
