Fao tony mon
Fao tony mon
Hi all, if Tony picks this up or if anyone has a contact number would they be able to pass it on please. My wifes uncles storm needs a bit of tlc and wondered if he'd make the journey to mid essex to have a look. If it helps, mine could have a once over if it makes his trip worthwhile. Atb, Gareth.
In the land of ham fisted, I am king
Re: Fao tony mon
I've sent him a PM for you...stealthbomber wrote:Hi all, if Tony picks this up or if anyone has a contact number would they be able to pass it on please. My wifes uncles storm needs a bit of tlc and wondered if he'd make the journey to mid essex to have a look. If it helps, mine could have a once over if it makes his trip worthwhile. Atb, Gareth.
Re: Fao tony mon
Thank you mac, much appreciated. I'm not sure what is up with the other bike but it's been laid up for a while so I suspect it may be a carb/ fueling issue. Cheers.
Re: Fao tony mon
Sorry, Gareth I am too busy to even keep my own bike rideable, as anyone who went on the Devon run will testify...... :@ I'd recommend a thorough carb clean and a sound thrashing.....
Good luck
Tony
Good luck
Tony
Re: Fao tony mon
What needs doing to it? there are a few of us local to you, we could even look at a maintenance day local to you.
Re: Fao tony mon
contact Jonesy, he's not far away and he's a bike mechanic, and an all round good bloke
Re: Fao tony mon
Jonesy
Is the bike / are the bikes capable of running under their own steam? Have you a list of what needs doing? A basic service or full service??
Re: Fao tony mon
My storms fine, only things I don't feel happy about tackling would be a c&s replacement and a brake system refresh, oh and a lightweight flywheel fitting (anyone got one floating about lol).As for my wifes uncle's storm, I presume where it's not ran for a while it's probably a carb/fueling issue, not sure its rideable but I'll find out some more and update. Thanks for your help chaps. Atb.Wicky wrote: Jonesy
Re: Fao tony mon
If you bring your storm beastie up to Colchester I can help you to do your C&S swap and change your brake fluid and give it a bleed.
Re: Fao tony mon
Thank you thats would be great, I've just got a couple of bits to do on her that I can manage and I'll give you a shout
