problem removing the front axel bolt
Re: problem removing the front axel bolt
I find a good spray with plusgas and leave overnight ,cover brakes before spraying, then give it some heft
I forgot to mention that the spindle bolt is made of titanium, will that have any bearing on things?
Only that it'll be more expensive to replace if you have to butcher it off. Can't see it having any effect on anything.
Sent from my SM-A300FU using Tapatalk
I got some fancy titanium pro bolt bits for my bike and they came with some anti seize compound................i didnt use it....... Now im worried lol.
- bigtwinthing
disimilar metals need some form of grease /anti seize etc. Stainless to stainless is the same but can be a bloody nightmare. It work hardens when you drill it too. Also s/s is not high tensile remember. Marty are you back in the UK now? if its rideable bring it down i will guarantee to get it off somehow.
bigtwinthing wrote:disimilar metals need some form of grease /anti seize etc. Stainless to stainless is the same but can be a bloody nightmare. It work hardens when you drill it too. Also s/s is not high tensile remember. Marty are you back in the UK now? if its rideable bring it down i will guarantee to get it off somehow.
- bigtwinthing
AP you didn't write anything in the last post!
bloody computer is playing up, i'm 99% sure I used copper grease when I fitted the spindle nut, i'd never had a problem with it in the past, hence why I think it's taken a knock in the accident....
have you tried slackening of the yoke bolts incase the forks arent sitting straight and putting the axle under some pressure?
If ur still using a socket or spanner with slight play in it try padding it out with a bit of rubber(a cut from from a roll of innertube puncture patches, or an old inner tube).
This should help the socket bite properly, although by the sounds of things that's not ur biggest issue. It does sound like the axel is under pressure from somewhere. Hope it works out dude.
- bigtwinthing
+1 thats a good onefabiostar wrote:have you tried slackening of the yoke bolts incase the forks arent sitting straight and putting the axle under some pressure?
I assume you mean the bottom yoke bolts?bigtwinthing wrote:+1 thats a good onefabiostar wrote:have you tried slackening of the yoke bolts incase the forks arent sitting straight and putting the axle under some pressure?
- bigtwinthing
If one fork is slightly higher (or 1 lower) the axel bolt will be pinched and may be slightly "cocked" so to speak. That may be making the bolt tight on 1 plane etc. Get the forks off the deck a bit. undo all the yoke bolts and retry .It may work.
- Pete.L
Really??
The forks are on springs and go up and down and the fork lowers can twist to any angle around the stanchions. You might get a bit striction from a bent fork or spindle but i don't think it would make that much difference. Tell your 19 stone body builder of a brother to stop being such a sissy and use that six foot scaffold pole you were talking about earlier. It should be more than strong enough to crack any bolt....or snap off the one you've got.
One way or the other it will shift.
- bigtwinthing
sorry brute force will always prevail then!. Is was a possibility that is not 100% lined up. Gring the head off then. Then worry about getting the rest out!. Or get a 150 mile scaffold tube, get Pete in Bristol to stand on it with the bike is Spain. Obviously red and white tape all along it as it would be a trip hazard!!!Pete.L wrote:Really??
