It won't hold on for long , Carl did this ,bolted it on with one bolt and bodged the other ,from what we herd it came off on the M40 on the way to the Dyno
bigtwinthing
Post by bigtwinthing »
you will find, soaking overnight with plus gas and then warming the nut up will have a massive advantage when removing these.. I always cut 1 side of the nut off with a small hacksaw blade and then the nut simply opens up and breaks in 2. This leaves the stud, clean up with a die nut and normally you are ok.
KermitLeFrog
Post by KermitLeFrog »
mellis wrote:Removed the headers to remove 13 years of crap, and........ snapped an exhaust stud GAAAAAARRRRGGGGHHHHHHHH feck it. Tried mole grips, reverse thread thingy and gone through two drill bits trying to make a pilot hole for the ez out. Nothing has worked so last shot is to dremel a slot and try to flat blade screwdriver it out. Wish me luck......
A bit late now but exactly the same thing happened to me. I couldn't use a welder where the bike was so, filed flats on the stub of the stud, used lots of heat and a pair of flat jawed mole grips. It finally came out.
Getting a good grip (with the flat jawed grips) on the stud was the trick.
Seems like it's a drill and helicoil job for you now.
Seeker 77
Post by Seeker 77 »
I think so, but none of my HSS drill bits are making a dent in it. It seems to be made of tungsten! I've got a decent DeWalt drill and matching bits but thinking a garage may have tougher gear?
KermitLeFrog
Does it have a bit of broken easyout left in it? No standard HSS drill bit will touch that.
Seeker 77
Post by Seeker 77 »
KermitLeFrog wrote:Does it have a bit of broken easyout left in it? No standard HSS drill bit will touch that.
Nope, it's just the body of the bolt still in there.
bazza696
Post by bazza696 »
Thought I would start to wiring in my sparkbright battery monitor on the CBF along with the eastern beaver switched fuse box. Well the fairing was a bloody nightmare to get off, then I found how shocking the previous owners wiring of the heated grips. So I have to undo all the work he done. Caused its sh1t I will remove them completely. Have to order some new grips now. So I have not got much further than removing the fairings and chip a load of shite wiring out.
Finished the bike's new home. All I need to do is build the ramp for the front next weekend and I can start creating space in the garage so I can get around to finishing the damn thing.
kev64
Post by kev64 »
Removed wheel and forks, got some wavys discs to go on, new tyre
Fork oil and paint the lowers :D
Polished me pipes....oohh er mrs!
The Leo Vince cans & links that were on the Custard Crumble were looking a bit sad, so gave them a spruce up, came out nice as it happens... :thumbup:
tony.mon wrote:
MacV2 wrote:Pulled Custard Crumble, Split nice & firm crack.
moody fixing & screw...
Ripped the fek out of a pair of trews as I kept catching them on the bar sticking out of the padockstand... :crazy: :lol:
Drill a hole in an old squash ball and stick it on the end.
Works with rod and square types of stand....
Wasn't that bad I didn't squash me balls just ripped me trews... 8O
Have you got any old balls ?
Silly question he's nearly 60.... :lol: :lol:
But still playing squash, so yes, you unhealthy rodent murderer...
I still have enough old (worn shiny) balls to share with a good friend like you.....
kev64
Post by kev64 »
Gave the front of the engine a good Gunking,
then took the starter motor off and gave that a good clean
ready for painting :thumbup:
Took the bird in to have an engineers report done as the insurance requested (only after I took out the policy) because it was a cat,c back in 2013 !
did you know that when you bought it~?
