That with your sonic cleaner?!
- StormyRob
Oh, was it a silver one?
I can still see bits of my boot sole in the treads on the pedal end, best do it properly.
And it'll rot in no time now you've removed the protective coating of road tar and chain grease......
- StormyRob
Still looks pretty nice!
Changed the...
Battery
R/R
Plugs
Spayed wd40 in all the multi plugs
Jobs to do...
New Vac pipes
Fuel lines
Clean the K&N
change oil & filter
at least she's half ready if i have to sell her
Battery
R/R
Plugs
Jobs to do...
New Vac pipes
Fuel lines
Clean the K&N
change oil & filter
hahahahahaha it won't take long for it to get covered in crap again mate....tony.mon wrote:Oh, was it a silver one?
btw i'm that sad I even cleaned up the spring....
I'm sure I could find a few more bits for you to clean Marty
hahaha I bet you could mate, but i'm trying to cut down on the revels....Duffy1964 wrote:I'm sure I could find a few more bits for you to clean Marty![]()
Changed oil&filter ,
Stripped and cleaned all the calipers and drilled the middle piston ,so now I only have one rear brake line .
And gone to a 14mm front brake master cylinder .
Fitted all new sbs brake pads too.
Also fitted a new sprocket carrier bearing .
Ran out of time so I couldn't test ride it so it's going to have to be in the way to work in the morning .
Fitted new rear brake lever from when I broke it at mallory park, fitted new rear brake line, shorter so it's now away from the engine and exhaust, relocated and fitted new res for the rear brake and re bled the fronts
happy birthday me, presious time with the bike
Sent from my SM-G920F using Tapatalk
- StormyRob
Decided to make a start on the radiator clean up and paint. Both very badly corroded. Decided to paint them black to go with the frame etc.
Only managed one because I lost the other tin of paint!
Once again. Better than it was.
Sent from my E6653 using Tapatalk
Simples, crashed it!!!!
you plonker, I hope your ok buddy.VTR Phoenix wrote:Simples, crashed it!!!!
agentpineapple wrote:you plonker, I hope your ok buddy.VTR Phoenix wrote:Simples, crashed it!!!!
Cheers agentp, swollen knee, swollen hip and somehow the padding on my jacket moved and gave me a road crashed inner elbow and bruising. Oh pride a bit dented as well. Bike still rideable but battle scared, nothing a bit of filler and painting won't cure. Managed to keep my head off the floor so saved myself £350 for a new lid. On the plus side, called in sick for work tonight lol.
Only damage to the van was a cracked rear light.
Sorry to hear that fella. Hope you're not in too much pain.
