Swapped the loom over on Custard Crumble...So after a strip down B/Work, tank & heat sheild.
Unplugged all the conectors front to rear. Then it's pull the old loom out...
This is where it gets tricky & more stripping to facillitate removeal & then smooth replacement...
Left hand rad unbolted & popped off the bottom holder, undo the top clutch holder on the headstock to free the loom...That allows you to feed the big bundles though the gap & have better access to the front coil conector block, also pulled the front cam box to air box hose again for better access...
Now at the rear the bundle & big plugs wont go through the gap between the battery box & the frame, so undo the rear of the under tray pull it down off the subframe & you just about have room to pull it through...Once this far the compleat loom pulls out...
First bolt of strip down at about 12.30 loom on the floor in a heap...13.45...
Headed in for tea & a smoke at this point...
So back out at a bout 14.00 & start feeding in the replacement loom, I start by feeding the rear bundle & the ecu plugs up through the gap & just leave as is for now, then thread the loom up though the gap behind the rad then just let that hang.
Start reconecting in the middle at the thermostat 3 plugs if that all lines up the front to rear has to be roughly in the right place...
One more conector on the left side of the motor the plug in the front coil, then feed the wire along the frontof the motor under the spar, clip in & route the TPS block & the rad switch...
Back to the head stock plug in all the blocks in the bundles & tidy up, then move to the rear just route it & plug in...
As after my recent breakdown I fitted a mossfet R/R I didnt want to chop this loom so I fitted the old RR back on, I can confirm it is fubar as when all up & fitted I checked it on a metre & with the bike running it was only showing 12 V... So I quickly stripped the rear end of Blooo & nicked the brand new Honda finned RR that I had put on that...Blooo can have the mosfet when I get round to it...
Loom all on start rebuilding, subrame & rear plastics, rad bolted back up, heat sheild back in, carbs reseated & tightened. Air box back on & whilst ther made up some new mini filters as mine were falling apart... I used some grey scotchbrite pads, just cut round one of the old filters cut a hole & popped them in...
& removed the cloths from the inlets...
lid back on, tank back on...fairing back on...
Quick systems check & all is good...lights all round, indis ect ect.
Tidy up, tools away, bikes back in the Cave shut the door & go in for a smoke & a coffee...At 16.30
Would havew got it done quicker without the break & to keep stopping top clean things before rebuilding...I even wipped the heat sheild over with a damp cloth...
Right I'm off for scran & watch the Moto GP...
