OP storm SW Scotland Mk4, July 29th to 31st 2016
Re: OP storm SW Scotland Mk4, July 29th to 31st 2016
boats all a bit fuked on the booked front . have to get the 15.30 so should be at the campsite about half5/6 then a bit of drinking and dancing to catch up on....cant wait..
Hope you boys enjoy you're weekend up here in Dumfries and Galloway Kirkcudbright is nice wee toon,weather looking to be ok the roads are great fun unfortunately I am unable to join up as working all week end typical .
I have recently (last month) been on St Marys loch road and Moffat beeftub road they had been recently chipped much to my disgust so take care if traveling these roads
hopefully I will meet up with you guys sometime when I'm not working
Just love the noise of a TWIN!
shame you can't make it, we need a few more locals to come out and play.awgh69 wrote:Hope you boys enjoy you're weekend up here in Dumfries and Galloway Kirkcudbright is nice wee toon,weather looking to be ok the roads are great fun unfortunately I am unable to join up as working all week end typical .
thanks for the warning on the chipping, hopefully 1 month is just enough for it to be clean
- Miztaziggy
You've always been Flatty it's a term of endearment
Sent from my SM-G920F using Tapatalk
That's a bit personal............. but trueMiztaziggy wrote:You've always been Fatty it's a term of endearment
time to check your chainfabiostar wrote:boats all a bit fuked on the booked front . have to get the 15.30 so should be at the campsite about half5/6 then a bit of drinking and dancing to catch up on....cant wait..
- Pete.L
Yep! make sure it's there or we will all be yanking it all weekend longAMCQ46 wrote:time to check your chainfabiostar wrote:boats all a bit fuked on the booked front . have to get the 15.30 so should be at the campsite about half5/6 then a bit of drinking and dancing to catch up on....cant wait..
This works great! Who said being Lazy doesn't pay off?AMCQ46 wrote:I found an easier solution - I am lazy.
1) don't even bother with Base camp, connect your GPS to your computer and download the GPX track file direct to the zumo. there is an internal folder called GPX, so put the file there.
2) switch on the Garmin and select the "Apps" icon from the home screen, then select" tracks" on that menu.
3) scroll down the "saved" tab and you will find your file, select the file and it will show it on the map.
4) there will be a spanner icon on the top right, so press that and from that menu select "convert to Trip"
5) once this is done the file will appear in your Trip Planner section and you use it as normal from there.
final tip is to disable the "off route recalculation" in the navigation settings - or set it to "prompted" so it wont change your planned route when you leave the path for any reason.
Well done Ali
and re check,twiceAMCQ46 wrote:time to check your chainfabiostar wrote:boats all a bit fuked on the booked front . have to get the 15.30 so should be at the campsite about half5/6 then a bit of drinking and dancing to catch up on....cant wait..
1 more sleep, and weather looks like it will be kind to us. perhaps a shower, but not real rain.
this will be fun
this will be fun
i hope you boys and girls enjoy teasdale and hartside on your was north..much better th an the M6
- Miztaziggy
Excited now :-)AMCQ46 wrote:1 more sleep, and weather looks like it will be kind to us. perhaps a shower, but not real rain.
this will be fun
Looks like we'll get wet tomorrow morning, but rain will be clear by 11am by the time we get to Settle, then all day up to Kirkcudbright.
Saturday forecast is clear too. Good times
I ha a boat booked for that time if you need itfabiostar wrote:boats all a bit fuked on the booked front . have to get the 15.30 so should be at the campsite about half5/6 then a bit of drinking and dancing to catch up on....cant wait..
Have fun boys & Alison...Enjoy the midges, hope it stays dryish for you.
Aviod the wild Haggis running around & don't come back with any NIP's.
Fabio make sure your tent zip is secure of a nigth time...
Have fun. Ride safe...ish.
- Miztaziggy
Hope you avoid rain on way up Al, it's pissing down here.
See you at Settle.
See you at Settle.
