Master Cylinder (brake)
alan
Post by alan »
I am wanting to upgrade the front brake master cylinder i know its been said before of the upgrade to rc51.
I just have a couple of questions: i have 929 calipers and braided hoses but have not had the chance to try as my bikes not finished will a ducati 996 master cylinder or 929 be a better upgrade than the stock item?
I have searched for a rc51 master but without success your advice would be appreciated
thanks Alan
P.S.what bore is the stock item and what bore should i upgrade to?
cupasoop
Post by cupasoop »
an rc51 is the yank name for the sp1 / 2. try searching for that.
Rich.
alan
master cylinder
Post by alan »
Yes i have Cupasoop
mik_str
Post by mik_str »
I believe that the 929 and RC51 MC are the one and same (both have 19 mm piston diameter). I just fit a RC unit on my VTR and am very happy with the result.
BTW, stock is 14 mm (and 954 is 17 mm)
cheers
Mikstr
alan
master cylinder
Post by alan »
Thanks Mikstr
do you know if the gsxr range is a 19mm?
alan
master cylinder
Post by alan »
The master cylinder for the k3/k4 gsxr 1000 i meant to put :D
mik_str
Post by mik_str »
Hi Al,
couldn't give you the reply to that one. You can check the owner registries at http://www.micapeak.com as there is a wealth of info there from owners who have modded their bikes. In terms of the MC diameter, try a search on Google, you can surely find the answer there. Good luck :)
Mikstr
