Elchappo76
Posts: 75 Joined: Mon May 22, 2017 12:47 pm
Post
by Elchappo76 » Mon May 29, 2017 11:42 am
Elchappo76 wrote: Elchappo76 wrote: Elchappo76 wrote:
Geez ..would you have an idea on $$
Sent from my SM-G900I using Tapatalk
I think my front cyl head ok and vavles .will strp clean and reasemble .small relapping should be ok and seals.
Hi tony . Well after pulling my case off .ive discovered more something jus not look write here ...any ideas pls .
Not mention .im intrigued by the difference between front and rear cyl covers .
Elchappo76
Post
by Elchappo76 » Mon May 29, 2017 12:03 pm
Ok .sorry am aware that this is normal now....just took my att straightaway. .loll
Posts: 16581 Joined: Mon May 11, 2009 4:54 pm
Post
by AMCQ46 » Mon May 29, 2017 12:04 pm
i can't see anything weird, what have you spotted?>
Elchappo76
Post
by Elchappo76 » Mon May 29, 2017 12:06 pm
AMCQ46 wrote: i can't see anything weird, what have you spotted?>
Hi ..sorry just found that its normal for that outer cogg to look abnormal to me.
Elchappo76
Post
by Elchappo76 » Mon May 29, 2017 12:07 pm
Posts: 16010 Joined: Wed Jul 25, 2007 10:46 pm
Post
by tony.mon » Mon May 29, 2017 1:01 pm
Gear is normal, but it seems likely you've had a valve, valve stem seal or guide failure allowing exhaust gas into the cam cover.
Is that piece of metal you found steel or alloy?
Elchappo76
Post
by Elchappo76 » Mon May 29, 2017 1:03 pm
tony.mon wrote: Gear is normal, but it seems likely you've had a valve, valve stem seal or guide failure allowing exhaust gas into the cam cover.
Well it looks lot lime the stainless steel from exh joint seal.
Elchappo76
Post
by Elchappo76 » Mon May 29, 2017 1:05 pm
Elchappo76 wrote: tony.mon wrote: Gear is normal, but it seems likely you've had a valve, valve stem seal or guide failure allowing exhaust gas into the cam cover.
Yea and my thoughts as well.
Elchappo76
Post
by Elchappo76 » Sat Jun 10, 2017 7:34 am
Elchappo76 wrote: Elchappo76 wrote: tony.mon wrote: Gear is normal, but it seems likely you've had a valve, valve stem seal or guide failure allowing exhaust gas into the cam cover.
Well i thought cant be too much to a clutch holding tool...so out with the welder again..
Elchappo76
Post
by Elchappo76 » Sat Jun 10, 2017 7:35 am
Did job ..but bit bent ...should straighten on assembly.
Elchappo76
Post
by Elchappo76 » Sat Jun 10, 2017 7:47 am
Question. ..i have noticed the chain here on oil pick up ..to be unexpectedly loose ..is this normal.
Elchappo76
Post
by Elchappo76 » Sat Jun 10, 2017 7:48 am
Unexpectedly loose ..is this normal.
Elchappo76
Post
by Elchappo76 » Sat Jun 10, 2017 8:47 am
Hi tony .. is it normally the only way to remove flywheel with the special puller i supose i have to order in...
Elchappo76
Post
by Elchappo76 » Sat Jun 10, 2017 8:52 am
Also is it really necessary to remove flywheel to split case to remove pistons.
Post
by AMCQ46 » Sat Jun 10, 2017 9:55 am
yes it is normal for the old pump chain to be that loose
