Newbee
Geeman
Re: Newbee
Post by Geeman »
Hi...change the r/r...what does that mean...???
Re: Newbee
Geeman wrote:Hi...change the r/r...what does that mean...???
Regulator /Rectifier...or as its know around here the Rectumfrier...
The black oblong block 3 yellow wires 1 red 1 green... Take the electical juice from the generator, regulates & rectifeies it before sending it to the battery... If it fails, & those ones do due to heat cycles over time...It can overcharge the battery, boil the battery dry, melt the wiring, screw ya clocks up, burn ya elbow...
You need to fit either a latter fined type from either a late model Storm or a host of other Hondas or splash some cash & fit a Mossfet type...
A later model finned type yesterday...
viewtopic.php?f=38&t=41255
When asked about it's older relatives it replied...'They are shite dude, buy me & stop worring about a failure...Oh & as long as your block conector is not a melted wreak I'm plug & play''...
Cue Wicky & his Sh*t R/R pic...
Re: Newbee
What he said. :thumbup:
Re: Newbee
Geeman I have sent you a PM.
You should be able to read it but not reply...get posting & get 50 posts for full access.
j4weeson
Re: Newbee
Post by j4weeson »
Hello and welcome! :wave: I got my manual ones from Ade and would recommend them.
Geeman
Re: Newbee
Post by Geeman »
Hi again
Ordered cam chain tensioners from Ade. Fitted Renthal rear sprocket. Clutch and brakes bled and now working fine. New in tank filter fitted. Getting it road ready and MOT'd then during the winter i will repaint calipers...forks and get swingarm polished or powdercoated. Getting it booked in at Biketec in Stoke for setting up and tuning and fitting the cam chain tensioners...dont trust myself...
Geeman
Re: Newbee
Post by Geeman »
Well its all back together and running well. Doesnt look much different to the first photo i put on here. But its cleaner...all the dodgey wiring has gone and now sorted...the dodgey indicators sorted...the only problem is i think the clutch reservoir is leaking slightly. Oh and the headlight is rubbish.
Re: Newbee
Welcome aboard Geeman :thumbup:
Nice work with the polishing,
Geeman
Re: Newbee
Post by Geeman »
Hi all
Bike is going to Biketec in Stoke on Wednesday for MOT..Manual cam chain tensioners and tuning...fingers crossed it will be all good as have been asked to go out for a run on Wednesday afternoon/evening..weather permitting...keep you posted.
StormyRob
Re: Newbee
Post by StormyRob »
Geeman wrote: Sun Aug 13, 2017 9:38 pm Hi all
That must be costing a fortune. You would save quite a bit by doing the ccts
Geeman
Re: Newbee
Post by Geeman »
hi there...
I know where you are coming from but at the end of the day if I mess it up the engine is toast. The guy is very good and I don't feel confident fitting them and he has done them before. The bike cost me £1250 with a load of bits including a Abba stand which I have sold for £50 all the other bits will be up for sale. It hasn't cost much so far...proberbly in it for £1400 at the moment. I have a set of wheels with very good tyres which I might swap for the scrubbed tyres that are on at the moment...extra rear light...top yoke and straight bars...I am doing it to keep so I want it running right...thanks.
Geeman
Re: Newbee
Post by Geeman »
Hi all...
Re: Newbee
Nice use of circular saw blades on the wheels :lol: You have a bit of a Blue Flame theme going on with your bikes. I'm guessing the cans where part of the deciding factor when purchasing. What's HECKS? You may regret getting rid of the Abba stand.
Geeman
Re: Newbee
Post by Geeman »
Hi
No idea what HECS is...it was on the fairing already.
StormyRob
Re: Newbee
Post by StormyRob »
VTRDark wrote: Tue Aug 15, 2017 1:36 am Nice use of circular saw blades on the wheels :lol: You have a bit of a Blue Flame theme going on with your bikes. I'm guessing the cans where part of the deciding factor when purchasing. What's HECKS? You may regret getting rid of the Abba stand.
+1 on that. The abba standis by far the best piece of kit I have
