Make a good frame, engine and fork coating
Polyurea protective coatings are commonly used for the following reasons:
Abrasion Resistance
Corrosion Protection
Waterproofing
Chemical, Environment or Atmospheric Resistance
UV stable colors can be achieved
Almost no coating can compare to polyurea when it comes to attainable physical properties. Polyureas can be formulated to achieve a tremendous range of properties — from high elongation to superior tensile strength to hard or soft, all based on how the material is formulated and correctly applied.
'Indestructible' Polyurea Coatings
Re: 'Indestructible' Polyurea Coatings
That is gob-smacking
Wow, its like a bad ass ventureshield on steroids!
I have friends that fall of regularly that could use that !
South Coast
New South Wales
Australia
New South Wales
Australia
- Pete.L
Is one of them called Mac?
- freeridenick
Is this the stuff that's called Gun Kote (cote, coat) elsewhere?
