Running Problems At Higher Rev's
- CountryBoy
New member to this forum but not new to Storms
I,ve got a problem with the storm when it hits about 6.5 / 7 thou on the rev's, it starts to splutter and struggles to accellerate any more, drop below this point and its fine , feels like a missfire or fuel starvation. Its just come back out of storage from the winter and had the cam chain tensioners done just before going into storage, whilst in storage it was run once a week but only on tick over, its got remus race pipes fitted and has had for a couple of years with no problems, any ideas??.
CountryBoy??
CountryBoy??
- Stormin Ben
I had trouble with a coil breaking down, which made the bike run rough, but it was all thru the rev range not just high revs.... bike shop couldnt find fault untill they got a doner bike and swaped parts around took about a month to sort, everything i need for the bike seems to take 3 weeks from Japan, dont seem to hold parts in stock, bit pissy really
Craig from the land of the long white cloud. Teal VTR 2001.
Re: Running Problems At Higher Rev's
Welcome aboard CountryBoyCountryBoy wrote:New member to this forum but not new to Storms
CountryBoy??
When you had the CCT's replaced did you have it done as a routine service item or did one let go
- CountryBoy
FAO sirch345
FAO Chris
I had one go and caused a nasty mess why?
- CountryBoy
Cleaning carb jets
Thanks for all the advice i appreciate it, another couple of suggestions made has been check the jets arn't blocked in the carbs and check the timing is ok.
Firstly if the timing was out would'nt it run rough throughout the rev range, the problem only occurs from 6.5 thou and up.
And second how to you check the jets? , do you have to remove the carbs?
Any advice gratefully recieved.
CountryBoy
CountryBoy
Re: FAO sirch345
The reason I asked if you just changed the CCT's as routine maintenance and not because one let go was quite simply one of our members had a miss fire similar to yours after a CCT let goCountryBoy wrote:FAO Chris
I don't think he'll mind if you PM him, he is 'Stratman'
PS. I've replied to your email
