and on the rental website there is no comparable fat bar version of the ultra low street bike bar !!!!! , so I will put 7/8th clamps on it in the same position they are today
Dont like by the sound the retrofit of existing stem to another yokes with different diameter. I have draw of new stem where you can modify the lower part, make new one on cnc and press in. Just dont want to share in public, but no problem in pm. Maybe I can draw new one with correct dimensions. For free, not making any business ...AMCQ46 wrote: ↑Tue Nov 21, 2017 8:37 amhave to credit Lloydie with the homework on this mod, when he used CKs spare Touno Gen1 bits on his track bike. So, Yes, the forks are the same length as the storm and the yoke offset is also very close.... the big job is to retrofit an early Fireblade stem [in the last picture] into the aprilia yokes. that needs a machine shop to knock up some pressfit spacers both top and bottom.agentpineapple wrote: ↑Mon Nov 20, 2017 10:19 pm that's going to look sweet Al. how does the fork length compare to the storm, as I remember reading the storms fork length is an unusual one, longer than most sports bikes and shorter than most touring bikes.
Al have you tried the WRP site for bars? they seem to do a good range and its top class stuff.
So today I finished off the strip down of The Mervinators old motor.
He had said the oil light was staying on & this had started happening after we had done the MCCT on it & found some chewed up plastic bag in the front head... The head had deffinatly been off before as there was black sealent holdingthe rubber gasket in place & smeared around various point on the block, cam cover & on the cam caps. So it was deduced that somone had stuffed it down the tunnel as you do but failed to take it out. This was the type of bag you get when you shop in a cornner store real thin plastic normaly blue. We had pulled a load of it out that was in the head wrapped around the cams.
This is what I found today once I took the sump off...
This being blocked would explain the oil light being on.
This I assume is the reason the bike seized up...
The shells were showing signs of blueing as well.
No other apprent damage from the seizure, the bores are fine, piston tops & heads are a bit sooty/coked up, all the gears have their teeth.
Only one other point of damage is the clutch outer is fubar due to my ham fisted removal procedure...who needs secial tools...
Question for you all the clutch springs had green paint on them, would that be as standard or poss aftermarket ones...the plates & steels all look fine btw.
Yes the bits are all avaliable apart from...flywheel & the alternator cover, both were needed for the replacment lump, the cam covers are F2 so have the pairs valves in them. The cam cover bolts are being kept as spares. The upper case is needed by A.N.Other. All the other bits are there for the taking.
WTF!!!!!!!!!!!!
how the hell did that happen mac, and I thought I was a bad muck an ic
[quote=MacV2 post_id=454355 time=1511544360 user_id=1815]
[/quote
maybe this is worth a punt mac?
https://www.ebay.co.uk/itm/HONDA-FIREST ... SwmudaEyV0
[/quote
If it was a bag for life take it back and get new un...
Did you try Honda to see if you could get it done under warranty?MacV2 wrote: ↑Fri Nov 24, 2017 5:26 pm So it was deduced that somone had stuffed it down the tunnel as you do but failed to take it out. This was the type of bag you get when you shop in a cornner store real thin plastic normaly blue. We had pulled a load of it out that was in the head wrapped around the cams.
Thats a major fook up by someone..
holy sh1t that looks grim....as for the clutch springs i put new EBC springs in both mine and they were green...
Ahh..Thanks...
No wonder there was a problem Well found Mac,MacV2 wrote: ↑Fri Nov 24, 2017 5:26 pm So today I finished off the strip down of The Mervinators old motor.
Changed the front and rear "mini" indicators - they look alright but too small for my liking, this is a before shot:
- freeridenick
Liberated these from a members old engine.
freeridenick wrote:Liberated these from a members old engine.
