Project Varatrackerstorm or Firetrackerdero.
Varastorm
Post by Varastorm »
I've been looking at exhaust gaskets, are there good & bad ones?
I've seen these on eBay, they are cheap at £2.99p for a pair.
http://www.ebay.co.uk/itm/142576602544? ... Track=true
Thy all do the same job, but get everything lined up properly and the tail pipes equally spaced and height before tightening them up.
Varastorm
Post by Varastorm »
I'm just gathering all the parts together for Christmas morning Tony 8)
I was only asking because the original squished gasket ring looks copper & these look aluminium based :think:
The plan is to make some stainless manifolds which will be permanently bolted to the heads. The header pipes will be a slip fit held to the manifold with springs.
This idea will hopefully make the building of the system a lot easier. Just slip the header pipe into the manifold, line the bends up to the bits of cut tube then tighten the Mikalor clamps up ready to tack it up.
Once tacked up, slide the headers out & weld it up on the bench then slide it back in. Hopefully there will be no fafing with flanges, gaskets & nuts during the exhaust build & hopefully the header pipes go back the same every time. Well, that's the plan anyway :lol:
Varastorm
Post by Varastorm »
Been busy today making some flanges for the new exhaust.
Time for dinner :thumbup:
Varastorm
Post by Varastorm »
After lots of dinner & filing, burp.
Another little job sorted for under the Christmas tree :D :thumbup:
That was like hard graft just looking at the photos. You need a beer after all that :beer: :thumbup:
Varastorm wrote: Sun Dec 10, 2017 8:18 am
sirch345 wrote: Sat Dec 09, 2017 11:03 pm You're taking me back now
Both of my old Mini's had brass nuts (ooh err missus ) on the exhaust manifolds now you mention it, a smart move me thinks
I had a quick look last night Chris. They might of been imperial UNF, but there are loads of m8 fine (1.25) for sale on ebay.
The ones I remember were quite deep/long & had a small groove/nick half way down the flat. If they were grubby, it looked like it was 2 nuts. like a locknut that'd lined up perfectly.
If I was going to do this, I'd like to go nuts deep, oops, Ooh err Missus. I mean to get the deep nuts. :lol: :lol:
I'll have a look for some combo studs, M8 1.5 to M8 1.25 :thumbup:
I don't really remember the small groove/nick halfway down the nut flat, but for sure they were a long nut, at least twice the length of a standard nut. Certainly not metric you're right.
All this talk of nuts, anyone would think Xmas was around the corner :wink: :lol:
Varastorm wrote: Tue Dec 12, 2017 4:30 pm After lots of dinner & filing, burp.
Luv your work with header flanges 8) :clap:
It seems so unfair, you make it look so easy :wink: :)
The trouble is I know it's not easy, it's a lot of hardwork, especially in stainless steel rather than mild steel. How did your files stand up to the stainless :?:
Great work :thumbup:
Varastorm
Post by Varastorm »
Thanks for the positive comments guys :thumbup:
The pictures might make it look easy, but in reality they were a pain to make. All day it took me, I was frozen & it was raining on & off :thumbdown: But they're done now :thumbup:
I really didn't want to make these, but with the rest of the exhaust going to be stainless it was a no brainer.
As Chris mentioned, with them being stainless they were harder to work with too. As for the files Chris they are a good make & held up well :thumbup:
I'm looking forward to making the spigots, but the parts for that are still in transit from China.
Sorry if its a little picture heavy guys :thumbup:
brilliant work....keep it going :thumbup: :thumbup: :thumbup:
Varastorm
Post by Varastorm »
Thanks Fabio, will do :thumbup:
In between hoovering, housework, cooking & making bread :roll: I've been reading about exhaust stuff :D
I'm still toying with the idea of joining the pipes & the reason it get's done. I came across this vid in the search.
I appreciate it's a v8, but interesting all the same :thumbup:
Varastorm wrote: Tue Dec 12, 2017 10:59 pm Thanks for the positive comments guys :thumbup:
That's good news with your files :thumbup:
For me pic's are good :D
such a pain in the butt that must have been but what a job how they turned out :clap: :clap:
Varastorm
Post by Varastorm »
More goodies arrived today
One problem, the id measurement of 39mm doesn't correspond to the gaskets.
It must be what they'll become when crushed up to the recommended torque.
I'm disappointed with 39mm id when the pipe id is 42mm. I know it's no biggie in the real world, but when your fabricating a new exhaust it's an unnecessary restriction.
Lucky for me, when the spigots are fitted & all torqued up I'll still be able to reach in with a die grinder to clean the protruding gasket from the exhaust :D
Just hope they're not hollow :(
Varastorm
Post by Varastorm »
I did a couple of hours down the shed today & started fabricating the header manifolds.
This is the plan.
1. I've ordered two 45mm sanitary flow joints (not arrived yet!). The sealing faces are to be ground down to 51mm diameter to fit on the exhaust gaskets in the head.
2. I've cut a 50mm long length of 48mm diameter pipe to slide over the above mentioned flow joint stub.
3. Then I cut a 20mm long length of 51mm diameter pipe to slide over the above mentioned 48mm pipe.
4. The idea is.. the flanges I've made previously slide over the 48mm stubs & press on the 51mm stubs. Which then press on the ground down sanitary flow joints which sit inside the 48mm stubs & squeeze the gaskets.
Don't worry if it doesn't make sense, because I'm not too sure what I'm doing either :roll:
Here's some pictures :thumbup:
Varastorm wrote: Thu Dec 14, 2017 2:29 pm More goodies arrived today
I have a feeling they will be hollow filled with heat resistant material, otherwise they won't crush to remove any discrepancies if they were solid. Don't worry though, and so you don't feel so bad :wink: I bought a pair of those too a while back :lol:
I wonder what the I.D. diameter of the exhaust outlet is on the cylinderhead :?:
Good to see you making progress with the exhaust stubs :thumbup:
