Folks looking for some clues here.
My Speedo started started giving false readings so I took off the Speedo sensor with the plan to have checked and replace. Cleaned up and put it back on now I have a bike with no power to ignition!!
All I did was take off and then put back on. New battery fitted thinking it might be this and also didn't know how old it was.
All fuses good even swapping 30amp ones over in case ignition was blown and I couldnt quite see it.
Anyone have this happen to them or any clues to what is left to check please.
Thanks in advance
Bob
SP1 Strange issue
Re: SP1 Strange issue
Have you shorted out the pins on the diagnostic plug to identify the fault?
It will flash a certain number of times to give you the fault code.
What a tit I am....checking all again last night I hadn't put the earth strap back on it had fallen down the back of the footpeg. Doh
easy enough to do.
I was going to say a dodgy earth, but wanted to get the diagnostic feedback first.
Glad all's well now.
All put back together and just out on bike Speedo is doing the same again reading up to 20mph ish and then all over the place dropping to 0 etc. Knackered Speedo sensor I assume?
David Silver offered me a new one at £197 What's that all about I ask.
Any other models have same sensor?
Thanks
Thanks
Find the part No... Here...https://www.ronayers.com/oemparts/l/hon ... 0f-a-partsSP1 Bob wrote: ↑Wed Sep 26, 2018 6:02 pm All put back together and just out on bike Speedo is doing the same again reading up to 20mph ish and then all over the place dropping to 0 etc. Knackered Speedo sensor I assume?
Thanks
Then find equivilant here...https://www.bike-parts-honda.com/honda- ... pare_parts ...if there is one...
Thanks will give it a bash
Fair to say sounds like Speedo sensor failure aye?
Bob
Bob
37700-MAL-601 / 37700-MAL-602
https://www.motorcyclespareparts.eu/en/ ... -crankcase
https://www.partzilla.com/product/honda/37700-MAL-601
and same as CBR600F3
https://www.davidsilverspares.co.uk/par ... 700MAL601/
https://www.ebay.co.uk/itm/Honda-CBR-60 ... 3375174895
Superb. Many thanks to all for the assistance
