Well, hello everybody... my name is Vara....... & I have PH Syndrome
Pfff.. just back from the doctors Chris. Bad news I'm afraid.
Hi Tony, it's not me purposely choosing carbs that'll restrict the air flow, it's the price of the things that's restricting me
The whole idea was to get the fuel tank as low as possible & at the time I had a set of 40 dcoe's to hand. So I decided to run with them & it's just grown from there really, I don't even know if it'll run with them.tony.mon wrote: ↑Wed Dec 19, 2018 9:43 am Yes, I saw the chart, it looks like you'll run out of carb before you run out of revs!
I suppose what I was leading up to was why you chose the TC Weber rather than Firestorm carbs, or something similar.
I had an idea a while back to try to get Ducati 888 fi on to a Storm engine, they look to be big enough throat size wise.
You would need crank position and cam position sensors fitted, but not impossible.
But then, simply using the Duc engine or the whole bike would probably be less work.![]()
Another idea I had was to use late Varadero heads (Sensor for fuel injection) then maybe sp1 throttle bodies running a Varadero loom with a power commander to remaptony.mon wrote: ↑Wed Dec 19, 2018 9:43 am I had an idea a while back to try to get Ducati 888 fi on to a Storm engine, they look to be big enough throat size wise.
Thanks for that Fab, best info yet on Fcr'sfabiostar wrote: ↑Wed Dec 19, 2018 11:11 pm maybe not much help but a while back i was chatting to an Auussie who has a lightly tuned vtr, he went to to FCR42 carbs from the standard 48s in the hope of maybe finding something, from memory once jetted and set up it ran crisper and sharper through the rev range but he lost about 3 bhp right at the top on a dyno. but did say the gains in sharpness across the range was worth the pay off.
Yeah, that was my understanding. Flatslides are easier to setup than CV carbs and that was the benefit rather than performance.Varastorm wrote: ↑Wed Dec 19, 2018 11:30 pmThanks for that Fab, best info yet on Fcr'sfabiostar wrote: ↑Wed Dec 19, 2018 11:11 pm maybe not much help but a while back i was chatting to an Auussie who has a lightly tuned vtr, he went to to FCR42 carbs from the standard 48s in the hope of maybe finding something, from memory once jetted and set up it ran crisper and sharper through the rev range but he lost about 3 bhp right at the top on a dyno. but did say the gains in sharpness across the range was worth the pay off.![]()
What an amazing findVarastorm wrote: ↑Tue Dec 18, 2018 4:30 pmPfff.. just back from the doctors Chris. Bad news I'm afraid.
After an hour sitting in the waiting room watching sick abusers & other degenerates roaming around aimlessly It's my turn to see her. In I go & explain my issue.
She said I was a lost cause & there was no tablet/medication that could cure Pikey Hoarder syndrome.
Yur doomed lad![]()
So off home I go & blow me on arrival, the Parcel force truck driver is at my door with a parcel...
After a quick finger squiggle & a Merry Christmas hug the driver pushes himself off me, jumps into truck & hurriedly locks the van. Never seen anyone driving away & keeping eye contact for so long![]()
In I go & place the parcel on the table & slowly unwrap![]()
They are a set of "Italian" Weber 50dco/sp's. On closer inspection they look like new old stock.
They are the largest I can go carburetor size wise as the inlet manifold is 50mm diameter inside also.
These are fitted with 46mm chokes & should be good for 8300rpm before running into issues.
All the reading I've done about the Weber dcoe series carbs point out the fact that the choke size dictates were max power will be.
I also read that every application is different & tuning for top end power will compromise low end tractability & vice versa.
Now that I have 40, 45 & 50 dcoe's it should hopefully be possible to tune each one for what I want from the bike.
See, I told you I'd been a good lad![]()
Right then, what else do I need![]()
