Got bike out of shed
Got a job
Put bike back in shed
Stripped peripherals off dynobrake
Got a job
well i pushed the wheel forward as if iv a new chain fitted to find, the tyre hits the chainguard . so had to rip the wheel out and adjust the guard with a little grinder. back together and alls good. just need the chain to get here now, and a new front tyre and im good to go. oh and the tank painted.
made a scot oiler, using left over parts from one i got for adventure bike and some old sheep dosing guns
Sheep dosing?
Doesn't the rohypnol rot the plastic?
So had to pop down the docs today to pick up a new sick note but thought I would go to Maidstone J&S beforehand & pop in on the way back...
The idea was to look at a jacket I had seen online...Spada Camo II... So I tried it on, nice jacket if a bit crispy as new, but the collar was like a bloody neck brace... Just not comfy at all so bailed out on that + do I relly need another jacket ? J+1 = 6 so gave that a miss...Instead I looked at some lids...
Stated off with a HJC but that was polycarb so swervd that, had a look at another HJC Rapha 11 (?) OK but didn't feel quite right...Tried on a Shoei GT air...
The card took the strain...
Feckin £65 for a new visor !!!
A quick search reveals that Wicky says 8mm fuel connectors are too small (see link below)MacV2 wrote: ↑Mon Feb 18, 2019 11:02 amNo your not, it is a PITA...If we had three hands it would be easier, I doubt extra fingers would help much & I wouldn't know as I have the correct number on each hand...KermitLeFrog wrote: ↑Mon Feb 18, 2019 10:45 am Got the tank back on, now ready to roll it out and start it up.
Am I the only one who has real problems getting the connections on the fuel tap? PITA job.
I do use a wooden stick/tank prop to hold the front up tho that makes it a bit easier...
You could always get quick release joints for the pipes...
https://www.ebay.co.uk/sch/i.html?_from ... acat=10063
viewtopic.php?f=18&t=18681&hilit=fuel+c ... 40#p325950
Anyone shed any light on this
nice helmetMacV2 wrote: ↑Thu Feb 21, 2019 5:51 pm So had to pop down the docs today to pick up a new sick note but thought I would go to Maidstone J&S beforehand & pop in on the way back...
I got one last yr, the drop down sun visor is a good toy
nice looking lid Mac. think il buy some new gear in springtime and a lids on the books..
A little worm drive hose clamp works fine.sirch345 wrote: ↑Thu Feb 21, 2019 7:03 pmA quick search reveals that Wicky says 8mm fuel connectors are too small (see link below)MacV2 wrote: ↑Mon Feb 18, 2019 11:02 amNo your not, it is a PITA...If we had three hands it would be easier, I doubt extra fingers would help much & I wouldn't know as I have the correct number on each hand...KermitLeFrog wrote: ↑Mon Feb 18, 2019 10:45 am Got the tank back on, now ready to roll it out and start it up.
Unless you've replaced the standard fuel lines with braided, that is.
Don't clamp braided lines, take them to a hydraulic hose maker like protek.
what im about to do today to my bike . just about the fill the Pegaso up with fuel, call for my mate james and we are going for a naughty friday supermoto bash
- KermitLeFrog
Woo hoo. Just filled the Ape up for a Friday sneak off with mates. Can't waste this weather!
Thanks for trying to help Tony I found these hose clips:- https://www.ebay.co.uk/itm/273716037029 ... 3716037029tony.mon wrote: ↑Thu Feb 21, 2019 9:01 pmA little worm drive hose clamp works fine.sirch345 wrote: ↑Thu Feb 21, 2019 7:03 pmA quick search reveals that Wicky says 8mm fuel connectors are too small (see link below)MacV2 wrote: ↑Mon Feb 18, 2019 11:02 am
However I am more concerned about 8mm fuel connectors being the right size for standard OEM petrol pipe as Wicky says they were too small (see link below).
viewtopic.php?f=18&t=18681&hilit=fuel+c ... 40#p325950Wicky wrote: While things were apart tried to fit 8mm quick release fuel connectors - no way with the slop in the 10mm ID hose would they have sealed securely
Chris I've got some in the MacCave...somewhere...never got round to fitting them but intend to do so...sirch345 wrote: ↑Fri Feb 22, 2019 3:20 pm
However I am more concerned about 8mm fuel connectors being the right size for standard OEM petrol pipe as Wicky says they were too small (see link below):-
I also have a spare set of carbs so next time I'm in there I'll have a look & fit up & let you know...
