Blimey Vara there's no stopping you once you get goingVarastorm wrote: ↑Thu Mar 07, 2019 11:11 am I’ve started on the electrics & the battery box. I’m trying to think ahead & make bits that will/might do other jobs later on.
The initial idea was to make an aluminium box that would be able to be slid in'n out. Welded together out of the frame & slide it in when complete & be able to be removed if required.
My second idea was to make the box out of the rear subframe. I was just going to cut & fit 1mm steel plate in the subframe floor & sides & weld them in. Then I thought it would look a bit heavy duty/armoured car’ish.
Both the ideas were flawed because of the holes that were needed to be cut to enable the large electrical plugs
My next idea was to make an aluminium box that would be held together by various lugs & webs welded to the subframe. By doing it this way I would accomplish three things.
1. Increase the room inside the box.
2. Allow me to weld in heavy duty lugs that could hold exhausts either side & I’m still thinking of maybe a twin shock conversion as well.
3. Looks similar to a Harley XR under seat oil tank.
Here are some pictures.
You and the others who didn't know should have paid closer attention to the photo's on page 32
Wow you had the right make Kev, well doneKev L wrote: ↑Sun Mar 17, 2019 10:18 pm I wasn’t far off with this though!-
viewtopic.php?f=30&t=40362&start=240#p456931
It fecking interesting to me the things one builder dreads is one of the things I look forward to.
