Strange knock/misfire at 2500 rpm.
Don71
Post by Don71 »
Hi all
Just gave my new to me 2006 Firestorm (75000 kms, jardine slip ons, everything else standard as far as I am aware ) a wash and check over to see what needs fixing.
After washing and chamois dry I started it up and ran on the choke for a few minutes until warmed up (maybe 50/60 degrees showing)
After letting the choke back in (it actually slides in of it own accord but that's for a seperate question) I slowly brought the revs up to see that all was ok.
On passing through 2500 rpm on a steady throttle it gets what I can best describe as a knock/misfire on the engine . Seems to hesitate , knock , no backfire or anything.
Seems to be ok below that rpm and also above it on a steady throttle. All this in neutral at standstill.
I'll let the Bike dry completely to see if maybe it's just a hit of water on things down on some of the electrics , but in the meantime , any thoughts please from anyone who may have come across this issue before?
Don
Re: Strange knock/misfire at 2500 rpm.
When was it last serviced i.e airfilter, spark plugs? check TPS and breakable plastic choke fittings at the carbs, Carb set up
Choke knob has a plastic retainer at the back that can be tightened to increase friction, if it can't replace choke or use Honda special tool
Gravelrash
Post by Gravelrash »
I'll just say that if you jet washed it then it could be water somewhere it shouldn't be.
Sounds like a carb cough, they all do it, relax.
Don71
Post by Don71 »
Thanks guys for the feedback and info,
much appreciated
Don
