Hi
Will the Varadero shock fit on a Storm with little or no mods Please?
Regards Paul.
Varedero Rear shock
- bigtwinthing
Varedero Rear shock
Re: Varedero Rear shock
Carb or FI model shock? As different part no.s
The vardero shock is shorter than the storms with a different stroke and spring rate
Doesn't mean it won't fit as such but might find handling as result will be different.
- bigtwinthing
But why would you, what are you trying to achieve?
I suspect it will sit lower but be too soft in both spring and damping.
- bigtwinthing
my mate has a Varedero Ohlins shock Tony. Its actually 10mm shorter.
Does it have a height adjuster to extend the length?
