Cleaning
Max
Cleaning
Post by Max »
Anybody know the best way to clean Titanium exhausts ??
Max
Kitch
Post by Kitch »
Cleaning how? Just cosmetically, or super seriously to remove blemishes?
First option, tianium wont rust, so normal soapy water should do. You can even remove tough grime / chain lube etc with something like Autoglym degreaser spray.
Second option, most jewellers use acids (mainly citric acid as its relatively easy to get hold of and use) to bring up a high level finish. Wouldn't advise this unless you knew what you were doing.
Max
Post by Max »
Kitch wrote:Cleaning how? Just cosmetically, or super seriously to remove blemishes?
just so it don't look dirty, soapy water it is then, I just didnt want to screw up the surface
Max
Rincewind
Post by Rincewind »
if you've got anything on them that won't come off with soapy water, meguairs clay bar will get it off
its like a big lump of clay that you rub over it, good for paintwork as well
Never argue with an idiot, they will drag you down to their level and beat you with experience.
meintjiesj
Post by meintjiesj »
Akaprovic (spelling ?) recommend using WD40 to clean the titanium pipes.
Squiffythewombat
Post by Squiffythewombat »
meintjiesj wrote:Akaprovic (spelling ?) recommend using WD40 to clean the titanium pipes.
gotta love wd40 its brilliant!
Squiffy_The_Wombat
stu9000
Post by stu9000 »
Ive recently started using Parafin to clean of all the chain gunk on my stainless steel leo vinci cans.
Works a treat
red is the fastest colour;)
