Filter, Cans and Dynojet - power?
welshy
Post by welshy »
Just wanted to know what sort of power you guys are getting out of some race cans, a filter (pref K+N) and a dynojet kit with proper setup. Any body got this as well as a factory ignition advancer and a 15t front sprocket. I have this on order and was wondering what I can expect?
Cheers.
Welshy :-)
Bikeless :-(
blackstorm
Post by blackstorm »
Ive got the lot and to be quite honest the best mod is the £12.00 spent on the 15 tooth sprocket. 99 storm Ackropovich full race titanium system K and N filter, dyno jet + superchip ignition advancer 110 bhp ( at the rear wheel)
phil
petrolhead
Post by petrolhead »
Buying a a Suzuki TL1000S will be cheaper than putting on all the bits. It already has the 114 bhp, fuel injection, upside down forks and steering damper etc. OK, I know it is a Suzuki, but anyway.
welshy
Post by welshy »
Where did you get the superchip ignition advancer from? How much?
As for the TL. Well the cans, k+N and dynojet kit I am getting for £225, I have a blade front end/WP Shock and steering dampers are for girls! :) I do like the TL but for me the VTR is a far better all round bike and with a few mods to the suspension it has the handling to match, exceed the TL. Good wheelie bike though! :wink:
Welshy :-)
Bikeless :-(
WayneM
Post by WayneM »
111.8bhp :D
Yoshi headers, Art cans, open air box, K&N, Dyno Jet.
All work carried out by VTR Specialist DTT (DelTwinTuning) :wink:
welshy
Post by welshy »
Where are DTT then?
Welshy :-)
Bikeless :-(
masked gerbal
Power
Post by masked gerbal »
Hi
Got a set of high level Pro Series II ART cans and a K&N. Dyno got 108 bhp at the rear wheels. Nothing else done to the bike. The Dyno showed the power curve to be a bit fluffy at the bottom end, once above 5K though sings like a bitch ! Dyno man suggested that Firestorms don't like K&N filter and that the standard filter is know to perform better, interesting that.
Masked :twisted:
Now got the ART - Watch your ears !!!!
F*&^ Me They Set Car Alarms Off Too
Great !
WayneM
Post by WayneM »
DTT are based in Kent (Nr Dartford) totally recommended!
EGG
cans filters dyno
Post by EGG »
My storm kicks out 110.1 at the rear wheel and has 71.9 lbs of torque running with blue flame hi level and dyno and K&N filter Thats not the best bit the best bit is how much smoother it is now from low down and how much more mid range power i now have. Thottle response is also inproved. :twisted:
Better to burn out than just fade away!
smokin joes
Post by smokin joes »
110 bhp at the wheel
and on its day, with a following wind, and if I get the power on early enough will out drag an R1 out of a bend, seriously, I've done it several times, (waits for all the R1 owners to say baldrocks, but I dont care) :twisted:
perfect curve on dyno graph, (no lumps or dips)
K&N
Dynojet
Remus High level race
43 tooth rear
tw@ in the saddle
Geoff M
Sex is like air. It only becomes really important when you aren't getting any.
BlackHawk
Post by BlackHawk »
Yosh full system, Dynojet Stage 1 Kit, K&N filter, HRC ignition module and 108.4 HP actual at the rear tire.
All that at 5870 ft above sealevel (altitude where the dyno is)!!!!!!
Next mod is Moriwaki stage 1 Cams and high compression pistons - supposedly worth another 10 to 12 ponies!
There is no replacement for displacement.
EGG
Post by EGG »
Hi smokin joes i know its not baldrocks i can do R1's Blade Gsxr's the lot just wind it on and let big round things between your legs do the rest. :twisted:
easytouch
Post by easytouch »
[quote="EGG"]Hi smokin joes i know its not baldrocks i can do R1's Blade Gsxr's the lot just wind it on and let big round things between your legs do the rest. :twisted:[/quote]
Haven't come across anything that can pull me out of the bends, even on the track against race/track-bikes - normally R1s and GXSRs ! I recon it must be the oodles of torque... and he only thing I have on my Stormie are a set of Micron race cans that sound heavenly!
I experienced the same thing with my previous Stormie that was as standard as they get - and that was at 5500 ft above sea level. My friends on new Blades could never believe how I could stay with them and keep going over 220kph (when the 600 start lagging behind!).
Re-gearing my bike soon - can't wait to feel my eye-balls at the back of my scull!
Robbe
Post by Robbe »
Last year @ dyno day had 108bhp on standard cans with K&N and Dyno jet fitted.
This year with the Mig's fitted, was down to 106bhp, but 72ft/lb torque.
Reackon the filter needs a good clean out and the needle positions need checking for the dynojet kit, since its still running rich.
Robb
EGG
Post by EGG »
smokin joes wrote:110 bhp at the wheel
K&N
Dynojet
43 tooth rear
tw@ in the saddle
Geoff M
Come on smoking tell me more about different size sprockets. What do they actually do? Front, rear which is best to change? :?:
