dropped
doggit
dropped
Post by doggit »
a while back i dropped the thing onto the left hand side, all that broke was the indicator stem and cracked the panel inside where the nut is at the end of the indicator, but i want to replace indicators for minis and also this panel but not sure what its called i want to look on ebay so if i know the correct term it would be easier
doggit
The most affective way to turn petrol into noise without the side affect of horse power
This is the sort of thing you are referring to, not sure (but you can check your bike) but there could be more than one panel on each side so this advertised panel my not be the one you require, if that's the case, obviously the one you need is the one which carries the indicator, it's normal for that panel to be damaged when the standard indicators take a hard knock :!:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1
VTR1000KAZ wrote:
sirch345 wrote:This is the sort of thing you are referring to, not sure (but you can check your bike) but there could be more than one panel on each side, obviously the one you require is the one which carries the indicator, it's normal for that panel to be damaged when the standard indicators take a hard knock :!:
ok... so maybeeezz i was wrong ! :(
Flippin heck Kaz, the vino certainly has not affected you speed on the 'puter :!: :wink: :lol:
doggit
Post by doggit »
hi chris, just had a look on the bike and it is the one which carries the indicator, i will just have to take it off and trall around spare dealers for one
carl
doggit wrote:hi chris, just had a look on the bike and it is the one which carries the indicator, i will just have to take it off and trall around spare dealers for one
carl
Good luck with it :!: :)
