Legs off the KTM again to fit some fork socks to cover the bit Of exposed leg above the new lower mudguard.
Spacers for the discs have been painted and I am told the new ABS rings are going in to the post tomorrow..
Oh and then to celibtbrate all the money I saved not buying the wheel and the discs, I have blown that on a top spec hyper pro RSC damper and mounting kit.
As well as bling, it will be protection if the steeper geometry makes it a bit head shaky when I am chasing James over some Broads :)
Happy days :thumbup:
And the additional weight will help keep the front tyre nearer the tarmac sometimes.
That was quick delivery
And fitted some neoprene covers over the exposed fork leg.
Then put the damper porn on the bike
And put it all back together
Abs ring is done and in the post, so it will come apart again for that, but then it should be all done in case the sun comes out.
ABS rings arrived.
We’re all shiny and silver, but Sanded and sprayed them black now.
Looking good Al 8)
Al, that things looking real nice :clap: :clap:
this morning gave the LC a coating of ACF50.. and serviced the little scooter thingy i got a while back, oil change,spark plug and.... well thats about all that needs doing to it. service for a tenner :clap:
Washed the crap off Custurd, cleaned, adjusted & lubed the chain.
Swapped the l/h switchgear over, dispite a good flushing with contact cleaner it started playing up again so changed it for one I have stripped & cleaned.
Swapped the tail plastics back to the now repaired yellow one.
Had Frank pick some bits for posting out tomorrow.
Looked at Rusty the Storm & thought fek it cant be bothered today... :lol:
ABS ring installed and all ready to test. So now I have to pluck up the courage to grab the front brakes too hard on a slippy road to make sure the ABS works, not sure I am looking forwards to that 8O
Stomp on the rear brake first. Lock that one up and see if the ABS works.
Then, if it does , try the front at 15mph on a gravelly patch of road. Careful, I braked a bit hard driving onto my drive, touched a gravelly bit, brakes released, and i nearly went through the garage door :crazy:
Have faith, it'll work :thumbup:
After yesterdays... Looked at Rusty the Storm & thought fek it cant be bothered today...
Can you see whats wrong here ?
Good work Macster
MacV2 wrote: Sun Dec 06, 2020 5:15 pm After yesterdays... Looked at Rusty the Storm & thought fek it cant be bothered today...
Fixing bolts for the disc or there is a huge crack in the disc or so it appears from the photo :?:
sirch345 wrote: Mon Dec 07, 2020 12:56 pm
Yeah they ain't standard bolts...stupid little cap head allen bolts...
Plan is to get 'em off de-rust, spin the bobbins & hopfully be useable...if that is a crack... It'll be StorminBinLaden...
MacV2 wrote: Mon Dec 07, 2020 4:51 pm
Good luck in getting the disc off :eh:
Plenty of Plus-gas over night,
