Finally time to get thing moving again as my set of heads should be done sometime this week......though it is kind of funny the reaction to how much I want them decked. Was asked 3 times there and even got a phone call to check one more time.....lol
8541Hawk wrote: ↑Mon Dec 28, 2020 4:36 pm
If you get them decked that much you'll need to take a link out of the cam chain...
I'm just following Rogers instructions ...... He decked some of his even farther with no mention of messing with the cam chains
Though I am going a little farther than most as I'm running Mori pistons instead of JE
8541Hawk wrote: ↑Tue Dec 29, 2020 1:19 am
Alright, now I am curious: how much? FYI, I had 0.0015" take from mine with no issues...
I sure you mean .015" but I went a touch farther to .025 as I'm running the Mori pistons which should bring me very close to 11:1 as the final compression ratio
Slot the timing gears, yes.......mess with the cam chain length.....no need
I wasn't being serious about shortening the cam chain, you made it sound a lot more extreme than it turned out!
Are you going to dry build to check the squish? ( Not joking this time)
No worries......I just though it funny that I was asked if I was sure at least 4 times but then again even though it is a good shop with a great reputation this was the first set of VTR heads they have ever seen.
Yes I will check everything to make sure I still have the proper clearances though very confident that all will go well
Hawk,
have you set yourself a timescale for completion are you hoping to be ready for the spring?
Also, as you have been in touch with Roger, do you have a rough idea of final gains you hope to obtain?
I should be done by spring , early summer. The whole fixed income thing make it a little tough but The heads were the expensive bit.
After going through all the bits I am running with Roger, so he knows the entire "package," he said I should be looking at around 125hp when all is done
Hi Mike, glad you´ve started this project, fingers crossed for good result.
Regarding decking head, assuming your pistons have 10.6 CR with original head, 0.025 (0.635mm) should bring you 11.5-11-6 CR, which is still fine. For 11.0 CR you need approx 0.011" (0.28mm) head skim with Mori pistons. This is based on my old calculation spreadsheed, which is correct I believe.
I plan to revive my engine this year a bit as I didn´t ride it really much in past two years, finally putting new choke with needles (old is screwed in fitting), installing fuel pump a try FIL mod.
edit: I forgot this calculation is valid on the cylinder side, not really sure on heads, it is safe anyway ...
Yes I did miss type that ratio. I was going for 11:1 originally as I thought I had a good line on some oversized valves.
I turned out the cost really wasn't worth it to me so I went with the stock valve and a touch more compression.
It has been a long time coming but once I ended up with the set of Mori cams I either had to build an engine or start selling stuff off....lol
And if everything goes south, I still have the stock heads that are on the engine now
Got the heads back on the first, so now it's time to finish the tear down of the bike and pull the engine apart to start the fun bit
Well progress is kind of slow right now but the metric drill bits I ordered finally came in so it's time to try my hand at modifying cam gears so they are adjustable.
Also received the proper bit to finish adapting the weld on an-6 fittings to the engine fittings. Now to decide where I am going to mount the oil cooler.
This weeks other project is to set the valve lash on the rebuilt heads. Though, of course, my feeler gauge set was pretty thrashed, so waiting on the new set to be delivered.
Lastly, picked up a budget bike lift to make the project go that much easier. I had one but gave it away before my move as I didn't know if I would have room for it here.
So getting closer......
I found I could slot cam gears with a file, but I know that they were available to buy; from memory either by Moriwaki or another Japanese source.
No idea if there are any left for sale, though.
tony.mon wrote: ↑Sat Jan 09, 2021 9:10 am
I looked for one but didn't find anything. So I went with plan B of using a 7mm drill and a dremel.
It should work out pretty good though I do miss the day when I had access to a machine shop.
A mill and a rotatory table would make quick work of this project.
