- StormyRob
Got my hands on some exceedingly inexpensive High levels a little while ago. Came without fitting brackets but sent a homing pigeon to Fabios last night with some technical drawings (Da Vinci would be proud) and back came some plates. Fitted today and quite chuffed. Had to pull the indicators off so on the hunt for an integrated rear unit for ease.
Looking good Rob
I agree, looking good Rob
Were we meant to be spotting the changes between the two lower photos? I got to about 6...StormyRob wrote: ↑Wed Feb 17, 2021 4:58 pm Got my hands on some exceedingly inexpensive High levels a little while ago. Came without fitting brackets but sent a homing pigeon to Fabios last night with some technical drawings (Da Vinci would be proud) and back came some plates. Fitted today and quite chuffed. Had to pull the indicators off so on the hunt for an integrated rear unit for ease.
its weird how the red and blue cars are both facing in the opposite direction
Just about not too long. Not quite wheelbarrows.
I like!
I like!
- StormyRob
Thanks folks
Yea thought the best way to assess the change was a photo in the same place. Didnt realise so much of the street furniture would be the same. Might do it every time a change is made.
Next step, top yoke conversion
they look bloody lovely. make sure and look after my next bike for me
i'll be fitting my high levels at some point but right now i'm in the process of fitting yeti's single seat. just trial fitted it and i think it looks good. although its not necessary, i'm thinking about relocating the electrics under the seat hump. this would include the reg/rec and indicator relay so would need a plate welded in, also the starter solenoid from the left side. does anyone foresee any problems with doing that? i would need longer battery leads made up but the loom is fine.
Just rode it into & back from work same as Monday, Tuesday & Wedensday...
Filled it up again on the way home...
Long weekend ahead not back in till Tue's...
Do you think I should find a bit of time to clean it ?
It's fine.
Perhaps next year.
Perhaps next year.
Looking good Mac. If you do decide to wash it no Arthur Job’s!!
I like your theory on washing Tony... I mean they are always banging on about saving water...
I'm thinking if I leave it a few more weeks I can get some spuds planted, then a few weeks later I can go to work knowing I'll be able to have baked spuds for lunch...
What?
SAVING water?
I must have mis-heard.
I thought you could only wash your bike with your SHAVING water- and I've had a beard for years...
I'll have to consider buying a sponge.
Fitted a new Motobatt battery, on the XSR700, love these. My 2018 model XSR needed its first MOT next month so now its all clean of salt and all the commuting gear is moved off it, I took it in today. Bit worried re the number plate (small but apparently legal) and the loud to my ears Black Widow but it sailed through, no advisories so all good for another 12 months.
