Chain lubrication
Chain lubrication
I realise writing this I'm leaving myself wide open to all kind of jokes :!: but here goes anyway :wink:
What's the general opinion for the best lubrication to use for the final drive chain :?: At the moment I use a chain lube from Silkolene in a spray can which works very well, apart from the amount that flies off it making quite a mess, I was wondering if anyone has used a wax or grease type lubricant with any success :?:
alan
chain lube
Post by alan »
Hi Chris
i use engine oil semi synth as i have it lying around anyway give it a good soaking then dab it down with a rag get the surplus off then apply motul chain wax over the top sealing the oil in.
Alan
Badger
Post by Badger »
Hi Chris,
I use castrol chain wax, doesn't seem to fling off that much.
Alan
Fireman on a Storm
Post by Fireman on a Storm »
I tried the chain wax on my Bandit. I was not impressed the chain seemed very dry and not actually lubricated.
I just "clean" the chain every now and then with wd40 and then use a chain lube from a spray can.
You should oil your change AFTER a ride and then leave it to soak overnight, rather than before a ride. The chain does build up a small amount of heat that helps the oil soak in.
I'm trying some stuff from "Worth"
Its a special dry formula which doesn't fling off. :D
Time will tell if it works or not.
Stormtrooper
Post by Stormtrooper »
I would'nt use WD40 as it will dry out the o-rings and cause them to crack
better using a mineral oil and or chain wax (as per alans) suggestion
dookie
Post by dookie »
Also remember to oil the inside of the chain not the outside that way the lube spreads through the chain rather than flinging all over the swingarm.
There was a time i used to care
Many thanks Alan, Badger, Fireman on a Storm, Pete.L, Stormtrooper and Dookie for you words of wisdom, very much appreciated :!: :D
