Max torque cans
Max torque cans
As per title , I ordered 2 days ago arrived this morning, despite needing a larger than 51mm inlet and required hook and spring fitting all at no extra cost very impressed.
Re: Max torque cans
I've got Microns at high level.
One needs a new end gasket,wadding is blowing out.
The other is rattling,sounds like loose baffle?
Both have a tiny hole,maybe a grub/worm screw someone said?
Re: Max torque cans
A tiny hole in the end is usually for a screw to hold baffles / dB killer in place.
