Am I right in thinking this is currently set at it's softest setting, and the default should be:
Rear shock
Pre load (spring) position 2 of 7
Rebound 1 turn out (anti clockwise) from full in.
I assume, this adjuster in the photo is the Pre Load...? yes?
So it's currently on setting 1 and should go round a notch (am I right)
Also, where is the rebound setting adjusted?
Thanks.
