I noticed yesterday that when opening up the throttle while standing next to the bike that there is a fair load of soot coming out.
When i bought the bike the previous owner said it was fitted with a K&N filter, rejetted carbs and remus race pipes, it does sound and go very well but will it need tuning? is my best bet to put it on a dyno?
cheers
baz
Running rich?
Running rich?
Lovin the V-twin!!
hi there,
i was in the same boat after buying a 2nd hand 'storm with the same setup as yours..
the main issue is that a lean mixture is bad and a rich mixture is also bad ( for different reasons i and others can bore you with ) you really need to get it on a dyno and have peice of mind,
another cheap check is to take it on a good run and get the plugs out of the engine when it has cooled - check the colour and state....this will speak volumes and the guide to what the colours are is in any old haynes car manual or on the web...
cheers
rs
cheers
rs
