Ticking Over..
SlingVTR
Ticking Over..
Post by SlingVTR »
Recently had carbs rebuilt was ticking over 1200rpm constantly before, the rebuild was a clean and all the rubbers replaced...was fine after after a 20m ride. Next time i took it out for a heat cycle it was up and down between 1500/1100....any ideas?
Re: Ticking Over..
Air leak. Check the carb rubbers and make sure the carbs are properly seated.
You can check by spraying a little squirt of brake cleaner near the carb rubbers and see if the revs rise.
SlingVTR
Re: Ticking Over..
Post by SlingVTR »
Well just had a 70 mile ride and the tick over was fine again 1200rpm pretty stable, i guess the bike identifies as a female then.
Re: Ticking Over..
SlingVTR wrote: Thu May 01, 2025 6:20 am Well just had a 70 mile ride and the tick over was fine again 1200rpm pretty stable, i guess the bike identifies as a female then.
:lol: :lol: :lol: :lol: :lol: :lol:
acrmnsm
Re: Ticking Over..
Post by acrmnsm »
SlingVTR wrote: Sun Apr 20, 2025 11:25 am Recently had carbs rebuilt was ticking over 1200rpm constantly before, the rebuild was a clean and all the rubbers replaced...was fine after after a 20m ride. Next time i took it out for a heat cycle it was up and down between 1500/1100....any ideas?
Did you get this done by a carb specialist? How much and who did it?
1997 Red Storm, 3 others in bits...
"Devonshire born and Devonshire bred, strong in the arm and thick in the 'ead."
