Robbed
Robbed
I see I can was not able for a while. Well my storm got nicked about a month ago. The cop recovered it last week. I might, will need a bit of advice while I'm going to attempt to fix the damage they did. Ignition smashed, top clamp of tree snapped as well.fuel tank lock busted,seat lock at the back busted. All indicators broke, only LEDs I still have originals. Rear light missing. Side fairings on front left and right cracked. Rear tyre worn away from burnouts. Left mirror broken. Let you know if I find anything else. It's a long haul. Cheers sammy
Re: Robbed
Hi Sammy, sorry to hear of your misfortune.
I can probably sort you out with some of the bits, if needed.
From your list of bits... I have a full lock set & rear light. Poss a mirror...
When you say ''top clamp of tree snapped as well.'' Do you mean the top yoke ?
Number 13... https://www.ronayers.com/oemparts/a/hon ... top-bridge
Re: Robbed
Cheers Mac I have the lock set ordered from Holland it comes with the part you were talking about it's where the ignition itself sits , going for aftermarket mirrors. It's a lot more expensive bringing anything from uk to here since brexit with heavy postage and customs charges
- Pete.L
Re: Robbed
Toe Rags,
Let us know how you get on Sammy. Plenty of people here with good advice and knowledge if you get stuck with anything.
