Well done VTRmart, I bet you're well pleased about thatVTRmart wrote:![]()
Finally put the engine back together and took it for a spin this morning on the way to work..... It's fixed! I no longer have the misfire at 6k
I'm not actually sure how I fixed it, all I did was re-lap in the vavles in the front cylinder head, but it worked.![]()
I think either re-lapping the valves cured it (but my valves didn't get knocked when the CCT went, so I can't understand why this is the case)
OR
Stripping it and rebuilding it all carefully cured it... maybe I had a loose connection or something, but I'm pretty careful so I don't think I had missed anything first time round....
Anyway, I hope this helps others with the same problem!
It's also good too hear the out come of a problem that others have given advice on, as I see quite a lot don't seem to reply
