Hi All
Long time no speak.....again... damn this being back at work think....can i go back on reduntantcy had more time to chat you guys.
Got a bit of a weird one with my head light...well them and the clock lights. They all work but i find that when i go over a bump they seem to go a little brighter, and then they dim a bit again. It's not by a hugh amount but enough for me to notice.
Thought it might be a short or that there's a durty contact. Has anyone else ever had this problem before? Any ideas?
Also is there any way to make the lights any better....ice bulbs?
Oooo before i go forgot to tell you, i bought another bike... XTZ750 super tenere, thought it would be good for a winter hack and abit of a project.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1
Cheers all.
Jurgs
light issue
- Squiffythewombat
- Contact:
- LotusSevenMan
- Squiffythewombat
- Contact:
Hi Jurgs,
Apart from suggested ideas, I would check the block terminal conectors behind the fairing pull them apart and check for any corrosion on the connectors, if no signs of corrosion just give them a quick spray of WD40 before fitting back together. Before you do that check the connector on the back of the headlamp bulb, also check the bulb itself I have known the glass part of the bulb to come loose in the metal part, (don't touch the glass with your fingers)
