fitting hand guards to a storm?
Hanuman
Post by Hanuman »
I'm thinking of putting some of these barkbuster VPS handguards on the bike in color coded style;
anybody ever fitted motocross hand guards on a sports bike?
The Official Border Hooner.
2001 Storm.
2006 Hayabusa.
LotusSevenMan
Post by LotusSevenMan »
I assume that goes from the bar weight end to a point, err :?:
Are they for keeping the cold wind off your 'paws' more than normal protection?
Might be a neat idea. Need to see a set of these particular ones on a bike (any bike!)
Hanuman
Post by Hanuman »
yup - my figuring is that hot grips only warm your palms, your hands still get soaked if it pishes down and your finger tips still get frozzen.
With bar muffs you can get away with wearing summer gloves to increase feel and you keep the wind and rain off as well as staying warm enough. However they don't look very good & can be a bit of a faff.
Whereas the hand guards above look as though they were designed to go on a storm imho, they also protect your bar end and levers in an off, they stop the wind chill and rain from getting onto your hands and I reckon you can get away with leather race gloves.
I need to take some measurements to see if they would fit + work out if they would foul the fairing/tank.
2001 Storm.
2006 Hayabusa.
Fireman on a Storm
Post by Fireman on a Storm »
I think the tank would be fine but worry about the fairing!
LotusSevenMan
Yeah, I second that FOAS. I reckon fouling on the upper part of the fairing might be a big problem. CIC will need to do some close up work with them in his hand to check it out about the travel. I follow his sentiments though re. frontal windfactor. I don't suppose they have to be too high to protect the section from knuckle to joint though.
By the way, I have found the fingertips are OK with the heated grips.
Will be interesting to see if this mod works.
Hanuman
Post by Hanuman »
re: grips and finger tips - aye but you are in Kent matey, I'm deep in the border county for my hooning with caber tossing sporan clad haggis's galloping over porridge covered glens and it's fecking freezin up here. Multiply the drop in temps up here by the wind chill off the North Sea and you'll know what I mean.
2001 Storm.
2006 Hayabusa.
LotusSevenMan
Point taken! :lol:
Stormin Ben
Post by Stormin Ben »
I know from experience the cheapy M&P ones don't fit.
The top fouled the fairing
However, some lower profile ones like these may well do the job
The other alternative is to modify the lockstops on your bike so they don't foul the fairing (NB reducing steering lock takes a bit of getting used to!) 8O
But its not a very good one!
delmeekc
Post by delmeekc »
I use a pair of MSR XC Cold Pro gloves in the winter, not much protection (compaired to leather/carbon etc) but more feel than normal gloves (even summer ones) and so far waterproof. Got them from Jim Aim Motorcycles. They recommended them and I was abit hesitant as they felt loose but after a while they feel great, as used by the winter enduro guys. Worth a try as less then £40 too if I remember. Very warm, toasting in fact.
