Changing Heads
Squiffythewombat
Changing Heads
Post by Squiffythewombat »
As you guys know my front head is damaged and leaking oil everywhere. I have a perfect head off the old engine so that can be swapped over. My mecanic tells me this is a bit of a major job and likelly to cost around $200 which i obviously dont have!
Does this sound about right? i didnt think that swapping heads would be that much of a mission aside from the valve assemblies?
Toby
Squiffy_The_Wombat
Give it a go.
Your time doesn't cost you anything when you're doing it for yourself.
That bloke is probably estimating for a four hour job and thats about right at todays prices :evil:
LotusSevenMan
Post by LotusSevenMan »
200 dollars is only about 101.875 ukp so seems cheaper than normal cost!!!!!!!!!!!
I'll get my coat shall I?
Have a go yourself says I.
Good luck!!!
Fireman on a Storm
Post by Fireman on a Storm »
I thought aunt Sally was comming over for tea and Worzle Gummage was putting his best bead on! 8O
Jaglifter
Post by Jaglifter »
Squiffy. Do it yourself. Just follow the manual step by step. Its only like a jigsaw puzzle!
She's my idea of beauty and thats what I ride.
Beast
Post by Beast »
Have a similar job myself Squiffy.
Picked up another cheap Firestorm with a front cct problem and dropped a valve.
Havn't had time to look properly yet, just wondering if its worth spending upto £100 notes on another front cyclinder with all the bits or just wacking in another lump. :)
ChunkyMonkey
Post by ChunkyMonkey »
I have bought an accident damaged Firestorm and need to swap the front cylinder head.
Can this be done without removing the engine?
Any hints or tips to look out for?
Andy
TL1000R & VTR1000
Proof that 90 Degrees is HOT!!
Squiffythewombat
ChunkyMonkey wrote:I have bought an accident damaged Firestorm and need to swap the front cylinder head.
Andy
Hi Andy,
no, the engine will have to be dropped out the frame, this also means the rear has to be removed too as im sure you realise.
Beast- 100 for a head? surely you can find one on ebay for less than that? you have the knowledge to do it yourself so should be too hard? That said i think you can pick up an engine for less than 300 these days!
Squiffy_The_Wombat
ChunkyMonkey
Andy
Hi Andy,
Sorry i didn't realise. Why does the rear head have to come off too?
TL1000R & VTR1000
Andy
Not wishing to contradict you Toby (Squiffy) but I didn't think the engine does need to come out to remove the front cylinder head :!:
Jurgen has just fitted new valves to his front cylinder head and he didn't mention anything about removing the engine first, as I'm sure he would have if he'd had to.
I've just had a check in the Haynes manual and they definitely say the c/heads can be removed with the engine in the frame.
Andy you will need to follow a similar procedure as for removing the front CCT as in this link http://www.vtr1000.org/phpBB2/viewtopic.php?t=8326 before you get to the stage of removing the c/head, you will also need to drain of the cooling fluid before removing the c/head. REMEMBER THAT ANTI-FREEZE IS POISONOUS, so take care how you dispose of it :!:
ChunkyMonkey
Thanks for that Chris 8)
I'd had a quick look and thought it would be doable without dropping the lump.
No worries on the coolant score as the right radiator was reduced to mulch in the smash.
My game plan is to "Streetfighter" this VTR. I've just picked up some 'blade USD's and i'm on the look out for a T595 rear end.
I've also bought a sexy curved radiator as i'm not a fan of the twin rads on naked bikes.
Anyone ever fitted Nitrous to a Storm? 8O
TL1000R & VTR1000
kevg
Post by kevg »
Any of you cylinder head changers want to buy a brand new gasket, i ordered one by mistake...the guy in the shop didn't understand which ones i was after...had it a month or so, still in the wrapper, probably to late for me to get my money back on it.
£5 plus postage gets you a cheap one and me a couple of beers. £15 at dave silvers.
i just need to dig it out the garage.
cheerz
kev
ChunkyMonkey
kevg wrote:Any of you cylinder head changers want to buy a brand new gasket, i ordered one by mistake...the guy in the shop didn't understand which ones i was after...had it a month or so, still in the wrapper, probably to late for me to get my money back on it.
Jeez :(
I only ordered one on Friday :cry:
I'll have it as a spare..pm sent
TL1000R & VTR1000
kevg
Post by kevg »
sold to the monkey...i'll dig it out and find an envelope big enough.
cheerz
kev
Stormin Ben
Post by Stormin Ben »
kevg wrote:i'll dig it out and find an envelope big enough.
Its only made of paper, just fold it up and put it in a standard one :lol: :lol:
But its not a very good one!
