urgent urgent urgent
KarlosVTR
Post by KarlosVTR »
how do i time the front head up with the alternator marks? the instructions i got with my cct springs tsays there should be a RT mark i havent got this
someone please help. im desprerate
im in derby should anyone be in the area
my mob number is available on request
richard
Post by richard »
hi karlos,
as a quick response if you are on about cam timing then an easy way to get in the right ballpark is to :
- remove rear cylinder cover
- set it to TDC on compression stroke - cam lobes point together like / \ and i think RT lines up on crank marker and markers on the cams line up with top of the cylinder head.
- turn the engine over by 1 and 1/4 turns ( use starter or spanner on crank )
- you should now have a FT mark lined up on the crank marker
- you should have front cylinder cam lobes pointing away from each other, like \ /
if you search the posts you will see other posts on setting the timing, i think one had pictures
cheers
richard
Karlos,
I think I'm right in saying the RT mark is sat above the actual mark like
this:-
R
T
It's got to be there :!:
Here's how I time my bike for CCT changing:-
http://www.vtr1000.org/phpBB2/viewtopic.php?t=8326
KarlosVTR
Post by KarlosVTR »
be buggered if i know how i done it but i think ive sorted it.
both cct springs looked and stretched fine
howebver, my plugs were almost white upon inspection
anyone know where i can get 180 and 183 jets from? ive tried wemotos website but no joy
