Changing Heads
- Squiffythewombat
- Contact:
Changing Heads
As you guys know my front head is damaged and leaking oil everywhere. I have a perfect head off the old engine so that can be swapped over. My mecanic tells me this is a bit of a major job and likelly to cost around $200 which i obviously dont have!
Does this sound about right? i didnt think that swapping heads would be that much of a mission aside from the valve assemblies?
Toby
Toby
Squiffy_The_Wombat
- LotusSevenMan
- Fireman on a Storm
- Squiffythewombat
- Contact:
Hi Andy,ChunkyMonkey wrote:I have bought an accident damaged Firestorm and need to swap the front cylinder head.
Can this be done without removing the engine?
Any hints or tips to look out for?
Andy
no, the engine will have to be dropped out the frame, this also means the rear has to be removed too as im sure you realise.
Beast- 100 for a head? surely you can find one on ebay for less than that? you have the knowledge to do it yourself so should be too hard? That said i think you can pick up an engine for less than 300 these days!
Squiffy_The_Wombat
Sorry i didn't realise. Why does the rear head have to come off too?Squiffythewombat wrote:Hi Andy,ChunkyMonkey wrote:I have bought an accident damaged Firestorm and need to swap the front cylinder head.
Andy
TL1000R & VTR1000
Proof that 90 Degrees is HOT!!
Not wishing to contradict you Toby (Squiffy) but I didn't think the engine does need to come out to remove the front cylinder headChunkyMonkey wrote:I have bought an accident damaged Firestorm and need to swap the front cylinder head.
Andy
Jurgen has just fitted new valves to his front cylinder head and he didn't mention anything about removing the engine first, as I'm sure he would have if he'd had to.
I've just had a check in the Haynes manual and they definitely say the c/heads can be removed with the engine in the frame.
Andy you will need to follow a similar procedure as for removing the front CCT as in this link http://www.vtr1000.org/phpBB2/viewtopic.php?t=8326 before you get to the stage of removing the c/head, you will also need to drain of the cooling fluid before removing the c/head. REMEMBER THAT ANTI-FREEZE IS POISONOUS, so take care how you dispose of it
Thanks for that Chris
I'd had a quick look and thought it would be doable without dropping the lump.
No worries on the coolant score as the right radiator was reduced to mulch in the smash.
My game plan is to "Streetfighter" this VTR. I've just picked up some 'blade USD's and i'm on the look out for a T595 rear end.
I've also bought a sexy curved radiator as i'm not a fan of the twin rads on naked bikes.
Anyone ever fitted Nitrous to a Storm?
TL1000R & VTR1000
Any of you cylinder head changers want to buy a brand new gasket, i ordered one by mistake...the guy in the shop didn't understand which ones i was after...had it a month or so, still in the wrapper, probably to late for me to get my money back on it.
£5 plus postage gets you a cheap one and me a couple of beers. £15 at dave silvers.
i just need to dig it out the garage.
cheerz
kev
kev
Jeezkevg wrote:Any of you cylinder head changers want to buy a brand new gasket, i ordered one by mistake...the guy in the shop didn't understand which ones i was after...had it a month or so, still in the wrapper, probably to late for me to get my money back on it.
I only ordered one on Friday
I'll have it as a spare..pm sent
TL1000R & VTR1000
- Stormin Ben
